Post by neo0. » Tue Jan 26, 2010 1:16 pm
Wow. That looks very neat.. :shock:
Post by Pibuz » Tue Jan 26, 2010 8:22 pm
It is Stinkie! It is Stinkie! Take off your mask Poli: your secret has been discovered.
Doug Armand
Post by Doug Armand » Tue Jan 26, 2010 8:51 pm
Pibuz wrote:It is Stinkie! It is Stinkie! Take off your mask Poli: your secret has been discovered.
LOL
I just realised as a mod I can ban all of Stinkies out of focus images........hmmmmmmm........ :mrgreen:
Doug
Doug Armand
Polinalkrimizei
Post by Polinalkrimizei » Tue Jan 26, 2010 10:24 pm
LOL! I wish I could do such nice images! and I guess Stinkie doesn't always focus cause he doesn't understand the settings... :wink:
Thanks for the comments guys, the image is just playing with perspective. No postpro, everything modeled geometry (mainly real cubes), all the shadows are real. The orthographic view does the trick. A perspective view would show how it works, and make the image less interesting IMO. A LOT LESS INTERESTING. But if you really want I'll post it later, it is rendering atm.
Silmä
Post by Silmä » Wed Jan 27, 2010 7:18 am
Polinalkrimizei wrote:Thanks for the comments guys, the image is just playing with perspective. No postpro, everything modeled geometry (mainly real cubes), all the shadows are real. The orthographic view does the trick. A perspective view would show how it works, and make the image less interesting IMO. A LOT LESS INTERESTING. But if you really want I'll post it later, it is rendering atm.
The 4th cube from the left in the bottom line seems to be somewhat distorted...
Godzilla
Post by Godzilla » Wed Jan 27, 2010 10:15 am
I'll just quote my post from the challenge thread.. :)
First Interior render, there is almost no direct lighting (Light from the Chandelier is going through SSS material, and the light from outside is going through the glass, not an easy scene for an unbiased renderer), so it's still pretty noisy after rendering for a while.. I'll need to add some direct lighting in the next update.
See my WIP thread and the rest of this post here.
Post by PureSpider » Wed Jan 27, 2010 10:31 am
I so love following your house progress!
Always eager to see some more shots 8)
Post by Zom-B » Wed Jan 27, 2010 1:45 pm
seems we use the same table Zilla ^^
I also planed to set the big oneat this position of the house and the smaller one on the upper part near the balcony.
Post by StompinTom » Wed Jan 27, 2010 1:47 pm
Godzilla
You're house is looking awesome! Glad to see more Indigo users over there :) Now I just need to get my balls rolling and produce something...
Polinalkrimizei
Post by Polinalkrimizei » Thu Jan 28, 2010 11:21 pm
This is the "making-of", finally: the same shot shown on the previous page with perspective view.
Very good eye Silmä! :wink:
@Godzilla: if your are not registered on ronenbekerman.com, the image doesn't show up in this forum. At least in my case. Could you please attach a more forum-friendly version? :)
imp-default view.jpg (25.96 KiB) Viewed 5177 times
Post by StompinTom » Fri Jan 29, 2010 5:57 am
Polinalkrimizei
Nice! How did you get the orthographic effect? Long camera lens? You mentioned something about a sensor size...
Couple grass tests with the new experimental Blendigo script with particle support. I love instancing :D
No texturing, 40 minutes on my dualcore laptop, 3 different wheat objects
No texturing, 20 minutes on my dualcore laptop, 3 different grass objects
Phr0stByte
Post by Phr0stByte » Fri Jan 29, 2010 6:27 am
AMAZING!
Godzilla
Post by Godzilla » Fri Jan 29, 2010 7:36 am
I'm going to need to figure out how to do this... my competition entry currently takes ~2.5 minutes to export because of the 17M+ faces... :(
Polinalkrimizei
Post by Polinalkrimizei » Fri Jan 29, 2010 8:24 am
@StompinTom: Amazing tests, especially the wheat image is colored to richly (not sure how to express this...). Great to see what is possible with a setup that simple (3 objects, no texture) .
For the orthographic effect, I increased lens_sensor_dist in the .igs-file. It defines the distance between camera and lens. Default is 0.02 meters, I increased it to 1. So yes, very long lens.
@Godzilla: I registered to see your image, and it is really pretty good. It gives a great sense of the space in that room. Looking forward to see more!
Soup
Post by Soup » Fri Jan 29, 2010 4:09 pm
Man those grasses are absolutely beautiful!
Could you just use the quick export feature Godzilla? I think it just updates the igs and not the meshes, so it gives you opportunity to play with materials and avoid the long export times.
