MayaToIndigo 1.1.03
Re: [latest - beta] MayaToIndigo 1.1.03
Post by CTZn » Thu Oct 22, 2009 5:32 pm
Updated (hit my signature), tell me if that works for you.
Fixed: I assumed everyone was using windows 2000 default scheme like me, sure thing ^^
Changed: The Palette is now larger for materials, allowing the mapping button to show for relevant parameters.
Files to overwrite:
  • mti_EDI.mel
    mti_EDI_gatheringProcs.mel
arneoog
Post by arneoog » Fri Oct 23, 2009 4:35 am
Wee, Working now! :P
Thanks ^^
But the access to the mti_settings, not the window, but those in the attribute editor
under extra attributes, is still impossible after I've had it open once, then closed it..
Suuuuper quick test XD
Post by CTZn » Fri Oct 23, 2009 4:38 am
If you happened to download right after the creation of the previous post you want to update again, sorry for the inconvenience.
1# what could make absorbtion easier to set ?
2# Are mapping buttons (and extra Palette width btw) necessary to the workflow, provided that a right-click on the color swatch gives the same option ?
edit: wow cool I missed your post while typing mine !
Erf Arne, I thought you could figure it out on your own, I don't support the idea really...
Here's the full flavoured thing, lucky you:
if (`isUIComponentVisible "Attribute Editor"`||(`window -q -ex AEWindow`&&`window -q -vis AEWindow`))	updateAE mti_settings;
else	{
/*!*/	select mti_settings;
	ShowAttributeEditorOrChannelBox;
Paste, select and MMB-drag to the shelf.
That's one first image, nice :mrgreen:
arneoog
Post by arneoog » Fri Oct 23, 2009 5:08 am
I downloaded just now ^^
#1 - I will need to do some more tests :]
#2 - I think that would be a good thing, yeah ^^
Working good on old models too :D
This is great CTZn! :D
Another Quick Test
Post by CTZn » Fri Oct 23, 2009 6:57 am
Huhuhu thanks a lot :oops: now go find some bugs yeaah :twisted:
updated !
minor=removed Palette debug output strings
minor=added an asterisk for inline textures title in material's Palette (there is a MMB menu there (;
fixed="edit 'node'" item in that marking menu now opens the attribute editor if it was closed.
arneoog
Post by arneoog » Fri Oct 23, 2009 8:14 am
Cool :D
How do I do Black Body Emission? ^^
..not added yet?
Post by suvakas » Fri Oct 23, 2009 8:22 am
Congrats CTZn !
Seems like Maya is getting back to business. :wink:
Post by CTZn » Fri Oct 23, 2009 4:48 pm
Just back :)
Arne, you need to load the plugin to use the spectrumNode. That node is found under the utility/color section of the createNode window or HyperShade.
Post by CTZn » Sat Oct 31, 2009 3:44 am
Arne, what show stopper did you hit please ?
Don't fear to tell what's bad, that's how it'll get better :D
arneoog
Post by arneoog » Sat Oct 31, 2009 4:43 am
I added a list of wishes in the REQ thread ^^
Post by CTZn » Sun Nov 01, 2009 9:49 am
Updated:
- removed UI auto-updates for combo boxes
  • Fixes flickering. Manual update required, you may either select the node again or use the Palette menu to refresh
- added density for medium (indigoShader)
  • absorbtion multiplier for RGB spectrum only
    based on an earlier participation from Hellstorm
- added the option to set a custom value for scene unit
  • in meters
- minor UI edits
Update plugin and scripts !
arneoog
Post by arneoog » Mon Nov 02, 2009 8:34 pm
Sweet :D
Will be trying today 8D
Post by CTZn » Tue Nov 03, 2009 7:34 am
Updated - hotfix:
- Fixed a bug reseting texture parameters
  • A nasty one !
arneoog
Post by arneoog » Tue Nov 03, 2009 8:40 am
now it's working quite good, I must say :D
Great job 8DD
Post by CTZn » Tue Nov 03, 2009 10:09 am
Finally good enough to be called a beta, I hope (:
If we can have the usability of MtI confirmed then the phase 1/3 (private/very limited testing) will be terminated.
Phase 2/3 is about shaping and featuring MtI further (bridging the gaps), and also about gathering the most interested users around the Maya community. Obviously the less gaps the more users.
Phase 3 would be about real advertising, it'll fade in when nearly all Indigo features will be supported by MtI (version numbers will then match).
Still, we are into the tail of phase 1 :)
