+1 --> I always use english so don't enforce it on me ... I would go mad!fused wrote:+1ZomB wrote:So please don't force the system language for the GUI but let it stay choose-able
at every point!
very important!
take care
psor
at every point!
very important!
Should be set on install??OnoSendai wrote:Ok, I won't force it. But I guess the default should be the language/locale detected by the OS?
What he said!pixie wrote:Should be set on install??OnoSendai wrote:Ok, I won't force it. But I guess the default should be the language/locale detected by the OS?
if (langSET == false)OnoSendai wrote:Install time isn't the easiest time to set it. Maybe when you first run Indigo you can choose the language, and thereafter it can be stored in the registry.
That's cool with me!OnoSendai wrote:Maybe when you first run Indigo you can choose the language, and thereafter it can be stored in the registry.
.QFrame{
border-radius: 5px;
background: qlineargradient(spread:pad, x1:0, y1:0, x2:0, y2:1, stop:0 rgba(200, 200,200, 255), stop:1 rgba(160, 160,160, 255));
.QLabel{
background: none;
color: white;
font-weight: bold;
}Don't worry about that stuffBorgleader wrote: Also there was this particular entry which i found odd:Code: Select all
.QFrame{ border-radius: 5px; background: qlineargradient(spread:pad, x1:0, y1:0, x2:0, y2:1, stop:0 rgba(200, 200,200, 255), stop:1 rgba(160, 160,160, 255)); } .QLabel{ background: none; color: white; font-weight: bold; }
Reinhard is a name.Borgleader wrote:It seems I'm having a little trouble translating some of the more "technical" terms, such as Tonemapping, Reinhard
Wow thanksCTZn wrote:Hey Borgleader, the most accurate technical term for tonemapping in french is, I think, compression/compresseur tonal(e).
Below are a few derivatives that might fit as well, but my preference goes to the precited, again for accuracy.
compression/compresseur dynamique
modèle tonal
correction/correcteur tonal(e)
tonaliseur
you can open a language thread for further enquiries !
