Using a material from the Material Database
5 posts • Page 1 of 1
AtomFury
Post by AtomFury » Sat Sep 19, 2009 3:55 pm
When I download a material from the database here, it gives me a .pigm file. I've tried to import it through the materials by selecting EXTERNAL and then choosing the file but it does not work. How would I actually do this?
dakiru
Re: Using a material from the Material Database
Post by dakiru » Sat Sep 19, 2009 11:45 pm
Hi AtomFury. Try to unwrap (UV) your model. Indigo needs an UV coodrinates to use maps (textures, bumps etc.) :wink:
SmartDen
Post by SmartDen » Sun Sep 20, 2009 11:25 pm
AtomFury wrote:When I download a material from the database here, it gives me a .pigm file. I've tried to import it through the materials by selecting EXTERNAL and then choosing the file but it does not work. How would I actually do this?
pigm is a packed indigo material. it's a zipped file. just unzip it and you get an igm file and maybe some packed textured. the igm can be used in blendigo.
Check normals, dude!
AtomFury
Post by AtomFury » Mon Sep 21, 2009 3:50 am
SmartDen wrote:pigm is a packed indigo material. it's a zipped file. just unzip it and you get an igm file and maybe some packed textured. the igm can be used in blendigo.
...This would explain a lot... I didn't realize it was an archived file.
dakiru wrote:Hi AtomFury. Try to unwrap (UV) your model. Indigo needs an UV coodrinates to use maps (textures, bumps etc.) :wink:
I'm a novice when it comes to texturing, something I wanted to say first, sorry :(
So I need to unwrap my mesh via the UKEY and then apply my texture using that? Or do I just need to have it unwrapped in order to use an external texture through Blender's texture system? It sounds like that's what you meant, but I'm not sure.
dakiru
Post by dakiru » Mon Sep 21, 2009 10:23 am
I hope this topic may help. And also this one :)
