Indigo Binary Mesh (.igmesh) format with source code.
Post by suvakas » Wed Jan 14, 2009 7:54 pm
[edit]
Finally got it working !!
So problem solved.
Thanks guys !!
dougal2
Re: Indigo Binary Mesh (.igmesh) format with source code.
Post by dougal2 » Sun Sep 06, 2009 8:09 am
I wrote an igmesh reader and writer in python - see attached.
I tested by loading the mesh.igmesh in testscenes/ and writing it back.
The written back file was identical to the original.
After loading an object the following member vars are int:
magic_number, format_version, num_uv_mappings, num_used_materials, num_vert_positions, num_vert_normals, num_uv_pairs, num_triangles
The following member vars are lists of 3-tuples: vert_positions, vert_normals
The following is a list of 2-tuples: uv_pairs
The following is a dict: uv_set_expositions
the dict format is { index: name }
The following is a list of dicts: triangles
the dicts are of the format
'vertex_indices': <list of ints>,
'uv_indices': <list of ints>,
'tri_mat_index': int
I've no idea how it will perform with larger data sets yet.
igmesh.zip
(2.06 KiB) Downloaded 950 times
dougal2
Post by dougal2 » Sun Sep 06, 2009 9:35 am
Don't know where the bottleneck is yet, but here's a preliminary benchmark:
[EF 2009-09-05 22:09:08] Indigo export started...
<igmesh
                Magic Number:           5456751
                Format Version:         1
                Num UV Mappings:        0
                Num Used Materials:     1
                Used Materials:         ['clay']
                Num UV Set Expositions: 0
                UV Set Expositions:     {}
                Num vert positions:     495794
                Vert positions:         <list length 495794>
                Num Vert Normals:       0
                Vert Normals:           <list length 0>
                Num UV Pairs:           0
                UV Pairs:               <list length 0>
                Num Triangles:          991232
                Triangles:              <list length 991232>
                Data size:              33704068 bytes
[EF 2009-09-05 22:09:24] ...finished. Export took 15.297000 seconds
dougal2
Post by dougal2 » Mon Sep 07, 2009 2:21 am
Suv or Nick,
Can you explain the multi-uv ordering? I'm coming across the same problems.
Post by OnoSendai » Mon Sep 07, 2009 10:32 am
Hi dougal, actually I just checked in a python igmesh reader/writer to the blendigo src, if you want to have a look at that.
The UV ordering inteleaves the uv sets/layers
So if there are M uv coords per layer, and N uv layers,
and uv_i_j is the i-th uv coordinate in the j-th set/layer, then the UVs area laid out like so:
uv_0_0
uv_0_1
uv_0_N
uv_1_0
uv_1_1
uv_1_N
uv_2_0
uv_M_N
dougal2
Post by dougal2 » Mon Sep 07, 2009 10:48 am
OnoSendai wrote:Hi dougal, actually I just checked in a python igmesh reader/writer to the blendigo src, if you want to have a look at that.
Oh, right. That will be interesting to compare :)
I'm not sure if I know where you've 'checked-in' to exactly ... please PM or email me details.
The rest makes sense.
Cheers,
Doug.
Post by OnoSendai » Mon Sep 07, 2009 10:53 am
attached.
Ignore class OldIndigoMesh, use INdigoMesh.
I used the python 'array' module because it's faster.
Stupid scripting languages.
indigo_mesh.zip
(1.54 KiB) Downloaded 1031 times
Post by Whaat » Wed Dec 09, 2009 9:41 am
OnoSendai wrote:attached.
So, this Python IGMESH code is guarenteed to work? Or has it been modified/fixed since you attached it here, Ono?
I don't know Python but it looks fairly similar to Ruby. Any advice on porting this code to Ruby?
Post by OnoSendai » Wed Dec 09, 2009 10:03 am
SHould work for Python, yeah, but I think it uses quite python-specific techniques.
dougal2
Post by dougal2 » Wed Dec 09, 2009 10:08 am
OnoSendai wrote:SHould work for Python, yeah, but I think it uses quite python-specific techniques.
Nick's published igmesh code produces erroneous files on 64bit (linux only?) systems because of the Long data types used. (Should be ints).
Look in blendigo source since 2.2.8 for igmesh code that works more reliably.
Post by OnoSendai » Wed Dec 09, 2009 10:12 am
Oh dear.. sorry about that :)
Post by Whaat » Wed Dec 09, 2009 10:23 am
Thanks doug, will do!
Post by Whaat » Wed Dec 09, 2009 10:25 am
Yeah, but it looks like the process of packing the data into binary format is the same as Ruby. That's my main concern.
BTW, what's the difference between num_uv_mappings and num_uv_expositions? Will this number always be the same?
Post by OnoSendai » Wed Dec 09, 2009 11:33 am
Uv sets are the number of uv layers.
uv set expositions are naming of particular layers, of which there may be many per layer.
Daniel
Post by Daniel » Thu Sep 21, 2017 7:13 pm
At the risk of asking the obvious... ;) in Indigo 4 compressed .igmesh files were introduced, is there any documentation of the compressed format or how to unpack it?
