Fatal Error: SceneLoaderExcep: No 'spectrum' element found i
2 posts • Page 1 of 1
Eric
Post by Eric » Thu Dec 21, 2006 12:36 am
Hello,
when I try to run an exported XML-file, generated in Blender 2.42a, in Indigo v.0.6, I always get the following error-message:
Fatal Error
SceneLoaderExcep: No 'spectrum' element found in background element.
I use the Indigo 0.5test7 export script in Blender
When I try to delete the background-tag in my XML-files, the error-message doesn't appear anymore, but indigo.exe crashes when it tries to render.
indigo.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
AppName: indigo.exe AppVer: 0.0.0.0 ModName: indigo.exe
ModVer: 0.0.0.0 Offset: 0000ffa1
I'm new to Indigo and I followed the tutorial on http://www.indigorenderer.com/blender_tut/. This didnt'work too.
Does anybody have an idea what the problem could result from?
atmmatt
Post by atmmatt » Thu Dec 21, 2006 6:57 am
I get the spectrum problem when I either don't have a proper light sources. Do you have a sun light source? Maybe you have multiple suns. I also notice using the latest exporter I have to use sunsky and background won't work (maybe I need a background or something, exr?).
"To be, or not to be" That is a question?
