Trying to render form Sketchup Pro
6 posts • Page 1 of 1
shlomi_gon
Post by shlomi_gon » Fri Jun 12, 2009 3:56 am
Hello, i'm trying to render from Sketchup pro.
I use Indigo 2.6 and Skindigo 1.09 and I get the following error message:
Error: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: UV set with index 1 was exposed, but the UV set data was not provided. (In element 'mesh', around line 6, column 9)
What does it mean?
Tnx in advanced
Re: Trying to render form Sketchup Pro
Post by Pibuz » Fri Jun 12, 2009 5:38 am
Hi shlomi!
I don't think the versions you currently use are correctly matching.
You should work with the stable FREE indigo release 1.0.9 while working with the SkIndigo 1.0.9 stable exporter. Between the 1.0.9 and the 2.0.6 version of Indigo, many things are changed and many of them aren't compatible.
Though you might want to use a stable version for your tests, I suggest you download the Indigo 1.1.18 version (you find the download in the NEWS AND ANNOUNCEMENTS section), fully compatible with the SkIndigo 1.1.16 version (you find it in the SKETCHUP section).
Unpack the Indigo folder in the programs folder (no need to install), and follow the instructions you find in the SkIndigo zip files to correctly position your sketchup plugin.
Version 1.1.18 of Indigo is almost completely stable, and it offers you many features you can't enjoy with the 1.0.9 stable version. I tell you: i work with 1.1.8 version and I never had problems. So be cool about that :wink: .
If you want to learn something, download my FAQ in the Sketchup section: that could help you get started with the whole indigo-skindigo thing.
Enjoy!
shlomi_gon
Post by shlomi_gon » Fri Jun 12, 2009 6:26 am
Hello Pibuz!
Thank you for youe quick reply...
I couldn't find Indigo 1.1.18 and Skindigo 1.1.16 versions.
Can you please send me the links for it?
Best regards,
shlomi_gon
Post by shlomi_gon » Fri Jun 12, 2009 6:57 am
I found it...but in SKIndigo 1.1.16 - 'SUpreviews' folder is missing....
Where can I find it?
Post by Pibuz » Fri Jun 12, 2009 7:57 pm
Same topic you found SkIndigo 1.1.16
The first link refers to a "SUpreviews" folder. That's it. :D
rkremer
Post by rkremer » Mon Nov 22, 2010 8:47 am
Hello,
Hopefully this message finds someone in the know. I am new to this and would like to make a few renderings from skethup for fun. I have SkIndigo_1_1_16 and indigo_v1.1.18. I can not for the life of me (even after reading these posts) find the "SUPreviews" folder. Can anyone send me a link to where I might find this folder for the version I currently have?
Thanks in advance.
