Cindigo 1.1.18 - stable RC3
Re: Cindigo 1.1.18 - stable RC3
think im done with the isl stuff now. i had to rewrite major parts of the material export.
below a screenshot of the shader. texture indices have to be written as as placeholders like "$tex01$" bacause indices of the loaded textures may vary.
next thing up is the import for isl.... not sure if i can find a good solution for used textures here.
edit: added another shot to show how to add an ISL shader. straight.
- shadertest2.jpg (24.59 KiB) Viewed 5042 times
- shadertest.jpg (38.28 KiB) Viewed 5045 times
mixing shaders
using the ISL shader feature.
heres an updated changelog so far.
changelog wrote:Cindigo 1.1.18 final (or RC4):
* added verbose = false and write_aperture_preview = false to preview scenes
* changed save period for previews to 10.0
* added import of ISL shaders
* added ISL shader
* restructured and rewrote parts of the material export
* added "Ok" button to about dialog
- 2649609426496104.jpg (40.22 KiB) Viewed 5035 times
@Zom-B:
about the different icon for materials with emisson, how about glowing pens?
- materialhelper_emission.png (5.52 KiB) Viewed 4975 times
errr... i admit it... im a workaholic!
changelog wrote:Cindigo 1.1.18 final (or whatever):
* spheres and external models can use light scaling now
* added glowing icon for material helper if emission is used
* fixed that exit portal gets exported, even if its disabled in the tag
* renamed "light normalization" to "light slcaling"
* removed infinite plane
* added ISL shader
[ut voice]
double post!
multi post!
m-m-m-m-monster post!!!!!!
[/ut voice]
sorry for spamming
double post!
multi post!
[/ut voice]
No problem, you deserve it
After all the great work you have done
sounds awesome fused, my list gets shorter and shorter
- zeitmeister
Thank you very much fused, I'll test your suggestion tomorrow!
hm, got 4 crashes now with Cindigo 1.1.18. I don't get a Mac version of Indigo (...) and so I normally render my scenes on OpenArtist (Ubuntu) after export.
After I've converted my material and go through the settings of them a "beachball of death" appears. I don't clicked preview or something like that. Any idea? Maybe the plugin tries to find a indio.exe?
Thanks
Helge
Thanks
Helge
Trainer | Consultant | Autor
. 3D - Maxon Cinema 4D, Blender 3D .
. www.hmaus.de
. www.pixeltrain.de
. www.hmaus.de
. www.pixeltrain.de
Fused, i cant find the RC4.
Is it ready?
The ISl stuff is really great!
Thanx.
Is it ready?
Thanx.
No, i have absolutely no ideaipartner wrote:Hi,
Thanks
Helge
Ill try to reproduce this beahviour, but can you maybe send me a scene where this happens?
No, its not ready yet. There are a few minor fixes left and is still need to do the "Quick render" button.tungee wrote:Fused, i cant find the RC4.
Is it ready?
Thanx.
cheers!
Hi fused,
here is my scene.
Thanks
Helge
here is my scene.
Thanks
Helge
- Indigo_hmaus.zip
- (901.59 KiB) Downloaded 284 times
. www.hmaus.de
. www.pixeltrain.de
. www.hmaus.de
. www.pixeltrain.de
another update
coming soonish.
Cindigo 1.1.18 final:
* material helper indicates the material layer by its color now (R10 only)
* removed light scale tag
* moved light scale settings to material helper
* disabled channels wont be exported anymore
* removed emission scaling from sphere, its not supported yet
* background material setting in render settings now uses a material helper tag
* removed background and envmap from render settings, added background material
* exchanged <blend_factor> with <blend> for constant values
* added <random_triangle_colours> to diffuse material
* added ISL shader
- layer indication.jpg (10.84 KiB) Viewed 4758 times
- pixie
Re: another update
Could you please set materials helpers with the same layers then of the Materials themselves? These way these could also be managed...
