Violet Update
The Unknown
Violet Update
Post by The Unknown » Mon Feb 16, 2009 12:56 am
Here is a little update of Violet with IGI-4 support, compatible with Indigo 1.1.17 files.
+ Support for IGI-4 (first layer only)
+ Checkbox to override SuperSampleFactor to 1
violet4.zip
Win32
(599.38 KiB) Downloaded 1722 times
violet4-src.zip
Source
(825.92 KiB) Downloaded 1469 times
SATtva_
Post by SATtva_ » Sun Mar 22, 2009 3:25 am
Wow! What about 64-bit version and Linux build?
Camox
Post by Camox » Sun Mar 22, 2009 7:05 am
Great, thxs ! :D
The Unknown
Post by The Unknown » Sun Mar 22, 2009 10:07 am
I have a Windows 32-bit system and i don't know how to compile a 64-bit version for Windows or Linux.
So, someone else has to compile the source for these versions.
Camox
Post by Camox » Mon Mar 23, 2009 5:30 am
Hi unknown, i have tried violet. It works very slowly and with glare, I have no results. Has anyone else problems or it works only for me so slowly ?
Post by pixie » Mon Mar 23, 2009 6:35 am
Strange... I was quite surprised with its speed (at least when compared with indigo)
The Unknown
Post by The Unknown » Mon Mar 23, 2009 7:56 am
Violet is running normal (slow) for me.
Glare is not visible at the begining (in my scenes), I have to change Weight/Radius/Tone-Mapping so see some difference.
Dev-Info:
I compiled it with VS Express and in Express there is no 64-bit available (i think).
And i had to disable OpenMP to compile without error.
The Unknown
Post by The Unknown » Tue Mar 24, 2009 5:33 am
Perhaps it's slow because of the missing OpenMP. Express doesn't support this.
Is there a developer with a Pro version?
Post by fused » Tue Mar 24, 2009 5:37 am
yep, here. downloading...
edit: need to get wxwidgets...
The Unknown
Post by The Unknown » Tue Mar 24, 2009 5:44 am
That's great news!
Post by fused » Tue Mar 24, 2009 7:45 am
heres the x86er built against wxWidgets 2.8.10.
building wx takes a while on an atom, :lol:
still having a problem building a x64 version, always getting LNK1112... investigating.
edit: wx x64 seems to build fine now (no idea why it didnt work before...)
edit2: here we go, violet x64
Violet_x64.zip
Violet 64-Bit
(775.96 KiB) Downloaded 1422 times
Violet_x86.zip
Violet 32-Bit
(606.91 KiB) Downloaded 1375 times
Post by CTZn » Tue Mar 24, 2009 11:46 am
More troubles now, the x86 doesn't run on my xp 32 rig.
Winrar says it's impossible to run the application and when it's copied to the HD on a random place it says (I'm translating from the french message):
"this application could not start because the configuration of the application is incorrect. Installing the application again could resolve the issue."
Post by fused » Tue Mar 24, 2009 11:52 am
weird. works fine here (win7 32 bit). will try it on xp tomorrow.
cpfresh
Post by cpfresh » Tue Mar 24, 2009 11:59 am
same error for me here on winxp 32-bit
Post by fused » Tue Mar 24, 2009 12:09 pm
still working here :)
might be a win7 problem. unfortunately its the only os installed on my laptop. will try to build it on vista when i get home on wednesday.
