[MtI] Moving code off my server
Post by PureSpider » Mon Dec 22, 2008 12:03 am
Haha okay the forum REALLY needs such an "You have new PM" function... I'll move it to my server instantly :D
Post by fused » Mon Dec 22, 2008 12:14 am
there is.... you have to set it in your profile - but firefox will probably block the popup if you didnt disable popup blocking for indigorenderer.com.
Post by PureSpider » Mon Dec 22, 2008 12:20 am
Eh okay... *goes searching for the setting*
€dit: The archive is destroyed... :D
dougal2
Post by dougal2 » Mon Dec 22, 2008 7:56 am
Sorry, I gzipped it twice by mistake
$ gzip SVN-mti-violet-jViolet.tar.gz
$ tar zxvf SVN-mti-violet-jViolet.tar
should work.
Post by PureSpider » Mon Dec 22, 2008 10:32 am
Yep it worked but what SVN conf do u use? o.O
I've never seen that *.passwd setup before...
Post by CTZn » Mon Dec 22, 2008 12:11 pm
Hey guys, I'm glad to know the packet is safe !
I let you set this up, anyway I could manage the MtI tree with that neurone (bang !)... no, that one (paf !)... ehr, wait...
dougal2
Post by dougal2 » Mon Dec 22, 2008 12:24 pm
Apache/2.2.9 (Debian) DAV/2 SVN/1.5.1 PHP/5.2.6-5 with Suhosin-Patch mod_ssl/2.2.9 OpenSSL/0.9.8g Server at hamsterfight.co.uk Port 80
I was serving the SVN using apache, the .passwd files are generated with apache's htpasswd utility for apache's Basic Auth.
Really though you can set up the auth however you feel comfortable - now you know which devs had access to the repos, just issue new passwords ;)
For the devs, this will probably just mean making a new checkout from the new repo, rather than trying a 'switch' command (in fact, part of me thinks that'd be a much better idea anyway).
this page will give you some clues as to what my apache config file looks like for my svn. subdomain:
http://www.howtoforge.com/apache_subver ... ository_p2
Post by PureSpider » Mon Dec 22, 2008 12:28 pm
Yeah I use svn protocoll instead of http, I feel more comfortable with that.
So I'll just take the passwords over to my svn config... devs, send me your PWs with PM, you will get the new SVN link in exchange then!
dougal2
Post by dougal2 » Mon Dec 22, 2008 12:33 pm
ah, one last thing, the post-commit hook for MtI might be active... i was using it to auto-build releases on my webserver a whle ago. You might want to disable it before the server tries to write files out ....
Post by CTZn » Mon Dec 22, 2008 12:39 pm
Do you think you could set something similar up, PureSpider ? Sounds handy !
Okay, I'm sending that to you.
Post by PureSpider » Mon Dec 22, 2008 11:21 pm
Okay for "similar"... Did you use a SVN client before or did you do your checkouts with something else?
Post by CTZn » Tue Dec 23, 2008 7:10 am
I use the Tortoise client.
Post by PureSpider » Tue Dec 23, 2008 7:15 am
Well okay then everything stays the same (atleast for you) :)
