Indigo 1.1.15
Kosmokrator
Post by Kosmokrator » Fri Dec 12, 2008 9:47 am
tnx ono... i like the new update....full speed optimized..
1.1.14 difuse test
432739.57834 samples / second
1.1.15 difuse test
587564.44675 samples / second
also this is on my new i7 core 965xe at stock clocks and x32 version!
nice work Ono
Post by Kram1032 » Fri Dec 12, 2008 9:55 am
yay :D great! :)
Post by OnoSendai » Fri Dec 12, 2008 10:42 am
delle wrote:Thank you Ono...
Question: :?:
"background_material" can be used with sunksy and/or exit portals?
Delle
Background material can't be used with sun-sky.
It can be used with exit portals.
joegiampaoli
Post by joegiampaoli » Fri Dec 12, 2008 10:45 am
zuani wrote:hi ono thanks for indigo and indigo linux release! :D
When loading scene diffuse trasmitter, indigo me by mistake!
in evry scene that contain texture,indigo me by mistake.....
Ok I can confirm this same error on indigo for linux 32 build. All textures can't be loaded for some strange reason, opened all xml files, checked paths and names and all looks well except when launching them under indigo.
Joe Giampaoli
My Indigo Gallery
Post by OnoSendai » Fri Dec 12, 2008 11:11 am
Ok, found and fixed that bug. Will post update soon.
zuani
Post by zuani » Fri Dec 12, 2008 11:29 am
Thanks a lot ono! :D :D
joegiampaoli
Post by joegiampaoli » Fri Dec 12, 2008 11:46 am
Thx again!
Joe Giampaoli
My Indigo Gallery
Re: Indigo 1.1.15
Post by CTZn » Fri Dec 12, 2008 12:49 pm
OnoSendai wrote: You can set background materials like this:
<background_settings>
		<background_material>
			<material>
				<name>background_material</name>
				<diffuse>
					<base_emission>
						<constant>
							<rgb>
								<rgb>1 1 1</rgb>
								<gamma>1</gamma>
							</rgb>
						</constant>
					</base_emission>
				</diffuse>
			</material>
		</background_material>
		<emission_scale>
			<material_name>background_material</material_name>
			<measure>luminance</measure>
			<value>20000</value>
		</emission_scale>
	</background_settings>
1) is the diffuse albedo declared implicitly ?
2) can we please know more on emission_scale::value types available ?
3) are those types available for materials emission too ?
4) Exit portals seems to be blocking most of the light coming from background_settings. If that was not with reinhard I could swear the screen is black with:
<value>200000000000000000000000000</value>
an exit portal and either linear or camera at maximum.
Re: Indigo 1.1.15
Post by fused » Fri Dec 12, 2008 1:25 pm
			<material>
				<diffuse>
					<base_emission>
						<constant>
							<rgb>
								<rgb>1 1 1</rgb>
								<gamma>1</gamma>
							</rgb>
						</constant>
					</base_emission>
				</diffuse>
			</material>
		<emission_scale>
		</emission_scale>
1) maybe yes, but its probably black. one should only use diffuse materials with emission, no albedo
2) have look at the manual, chaper about "model" element
3) emission scale in background_settings and model are exactly the same thing. again, check out the pages in the manual about it
4) no idea
Post by CTZn » Fri Dec 12, 2008 3:44 pm
Thanks fused, I missed that one.
Post by OnoSendai » Fri Dec 12, 2008 3:44 pm
Updated linux build, textures are loaded properly now.
joegiampaoli
Post by joegiampaoli » Fri Dec 12, 2008 3:52 pm
OK, thx!!!
Joe Giampaoli
My Indigo Gallery
joegiampaoli
Post by joegiampaoli » Fri Dec 12, 2008 4:28 pm
Just a note, as usual I always open antialias test scene to test I noticed this difference between windows + linux same 1.1.15 versions, below are screen shots, but I think it's mostly an error on the scene file since I also tried with diffuse transmitter scene and both render with same luminosity.
Just in case maybe it is something wrong with the scene file included in linux version and maybe not something with that indigo engine under certain scene conditions......
Joe Giampaoli
My Indigo Gallery
Macrob
Post by Macrob » Sat Dec 13, 2008 4:32 am
Hey Ono!
Thanks for the 1.1.15 and the new linux build. The 32bit version works fine now :D
PS: But where is the EMITTER mat in Blendigo1.1.14?
Post by Kram1032 » Sat Dec 13, 2008 5:21 am
Macrob, there is a button for EACH material to activate emit ;)
