Indigo 1.1.15
Indigo 1.1.15
Post by OnoSendai » Thu Dec 11, 2008 9:56 am
win 32:
http://www.indigorenderer.com/dist/indigo_v1.1.15.zip
win64:
http://www.indigorenderer.com/dist/indi ... 1.1.15.zip
linux 32: (requires wxGTK 2.8 )
http://www.indigorenderer.com/dist/indi ... .15.tar.gz
linux 64: (requires wxGTK 2.8 )
changelog:
* fixed unnecessary checking of uv sets when texture not used directly, but only by shader
* re-enabled TIFF texture support
* fixed interactive tonemapping when network rendering is enabled.
* fixed network rendering with multiple layers
* added layer names in GUI
* only displaying used layers in GUI
* Implemented proper shutdown of GUI in network mode
* added some more loading of scene stuff in network mode, so can get number of layers used.
* added layer names to IGI format
* fixed rare crash bug in WeightedSampler
* lots of fixes to make Linux builds work
* fixed render_foreground_alpha (was crashing)
* fixed exit portals for non-sky background
* RNG seed is now saved to IGI file, so that resuming a render uses new samples.
* added background_settings, background_material etc..
* fixed CIE colours having negative components, clamped to 0.
* Changed SSS a bit
* SSE2 is now required.
You can set background materials like this:
<background_settings>
		<background_material>
			<material>
				<name>background_material</name>
				<diffuse>
					<base_emission>
						<constant>
							<rgb>
								<rgb>1 1 1</rgb>
								<gamma>1</gamma>
							</rgb>
						</constant>
					</base_emission>
				</diffuse>
			</material>
		</background_material>
		<emission_scale>
			<material_name>background_material</material_name>
			<measure>luminance</measure>
			<value>20000</value>
		</emission_scale>
	</background_settings>
EDIT: see attached testscenes for an example of using the background material.
Please let me know of any bugs and issues found.
There is a known issue found by Fused involving missing triangle intersections with the kd-tree.
background_testscenes.zip
(2 KiB) Downloaded 622 times
Post by PureSpider » Thu Dec 11, 2008 10:00 am
Thanks! :)
Camox
Post by Camox » Thu Dec 11, 2008 10:26 am
WOW, thanks Ono ! :D
Post by pixie » Thu Dec 11, 2008 10:58 am
Ups! Ono did it again! :twisted:
Diffuse transmitter:
1.1.14 212305.37071 samples / second
1.1.15 283378.29581 samples / second
A mighty increase of 33%!!
:shock:
Post by OnoSendai » Thu Dec 11, 2008 11:11 am
pixie wrote:Ups! Ono did it again! :twisted:
:shock:
Yup, I did some SSE optimising, which helps a lot in geometrically simple scenes like this.
The Unknown
Post by The Unknown » Thu Dec 11, 2008 11:13 am
Thanks and great work!
eman7613
Post by eman7613 » Thu Dec 11, 2008 11:24 am
awsome stuff, can we get an IGI spec so violet can get up to snuff again :P
Yes i know, my spelling sucks
Onfame
Post by Onfame » Thu Dec 11, 2008 11:33 am
Nice Work ONO!!!
Only about 15-20% increase here :P
1.1.14: 237457 samples/second
1.1.15: 287821 samples/second
Processor Phenom 9950
Windows XP 32Bit
Post by OnoSendai » Thu Dec 11, 2008 11:51 am
added linux x64 build
cpfresh
Post by cpfresh » Thu Dec 11, 2008 12:25 pm
thanks for the update Ono! the network mode stuff is very welcome!
Post by Borgleader » Thu Dec 11, 2008 12:56 pm
OMG Thanks :)
Post by pixie » Thu Dec 11, 2008 1:52 pm
Amazing!!
284427.51999 samples / second
BMW Z4
Post by OnoSendai » Thu Dec 11, 2008 3:22 pm
Added linux 32 bit build.
dmn
Post by dmn » Thu Dec 11, 2008 4:54 pm
Yay!
Re: Indigo 1.1.15
Post by suvakas » Thu Dec 11, 2008 6:33 pm
Great! Thanks!
OnoSendai wrote:There is a known issue found by Fused involving missing triangle intersections with the kd-tree.
Is it the same issue I mailed you about a while ago or is it something else? (see the image).
Users browsing this forum: No registered users and 88 guests
