Black glass artefact w/o normal smoothing
- render @ 50 samples
- im1227467505.png (1.64 MiB) Viewed 3952 times
Here is the obj
http://www.megaupload.com/?d=L365QQGO
- PureSpider
- Borgleader
+2PureSpider wrote:+1ZomB wrote:I prefer that the lazy "artist" would gets his balls kicked each time he start bothering people instead of using his eyes to see the obvious...neo0. wrote:Would it be possible for indigo itself to check for these things and fix them in the best way possible?
Okay, einstain, tell me, what is so obvious here? I was making a simple suggestion.ZomB wrote:I prefer that the lazy "artist" would gets his balls kicked each time he start bothering people instead of using his eyes to see the obvious...neo0. wrote:Would it be possible for indigo itself to check for these things and fix them in the best way possible?
- PureSpider
+3, nice one Zom-B, pain may be the way for neo, after all. Indigo does check for degenerated triangles at startup time, and more. But it can not design things for you, so do things right.Borgleader wrote:+2PureSpider wrote:+1ZomB wrote: I prefer that the lazy "artist" would gets his balls kicked each time he start bothering people instead of using his eyes to see the obvious...
neo., what you need* now is to use another 3d package in addition with sketchup, because it is a great modeling tool but will learn you nothing on 3d at all. Take whatever modeler that suits you beside sk, and you'll learn a great deal on 3d. Now, balls on the table please...
Oh and I don't know sk very well, but IIRC it's basic shader is double sided, beige outside and violet inside, isn't it ?
* this was supposed to be obvious too.
- Borgleader
1. Its Einstein not einstainneo0. wrote: Okay, einstain, tell me, what is so obvious here? I was making a simple suggestion.
2. Pixie nicely said it earlier "the inner got out and the out got inner". Soo... keep the inner inner and the outer outer...this is what's so obvious here.
I wasn't asking it to design things for me. This is simply another error, like degenerate triangles that it could warn you about.Indigo does check for degenerated triangles at startup time, and more. But it can not design things for you, so do things right.
Sketchup isn't my modeller. The only reason why I use it is to export to indigo. I use Hexagon and Wings.
Sorry, bro, I don't swing that way.Now, balls on the table please...
