Some simple SSS tests
13 posts • Page 1 of 1
Post by OnoSendai » Sun Nov 23, 2008 12:36 am
I've been messing around with the SSS code a little, and wanted to test out an interesting SSS phenomenon that's easily visible in real life. This is where you position a thin, opaque object (such as a knife blade) above a SSS object. You can then observe light scattering underneath the occluding object, and exiting the surface on the far side of the occluding object.
Note that the thin occluding object is in exactly the same position in all 3 images.
The first image is a Phong material (non-SSS) reference.
The red material is defined like so, and the white material similarly, except that all absorption RGB coefficients are 10.
<medium>
		<name>subject_medium</name>
		<basic>
			<ior>1.3</ior>
				<rgb>
					<rgb>10 100 100</rgb>
					<gamma>1</gamma>
				</rgb>
			<subsurface_scattering>
					<rgb>
						<rgb>10 10 10</rgb>
						<gamma>1</gamma>
					</rgb>
				<phase_function>
					<uniform/>
				</phase_function>
			</subsurface_scattering>
		</basic>
	</medium>
	<material>
		<name>subject_mat</name>
		<glossy_transparent>
			<internal_medium_name>subject_medium</internal_medium_name>
			<exponent>
				<constant>
					100
				</constant>
			</exponent>
		</glossy_transparent>
	</material>
easyarchitect
Post by easyarchitect » Sun Nov 23, 2008 12:53 am
Indigo renderer 1.1.15 :shock: :shock: :shock:
Delle
Post by PureSpider » Sun Nov 23, 2008 2:07 am
Nice test!
Can you explain why that happens in real life?
I'm really interested in that phenomenon!
Post by OnoSendai » Sun Nov 23, 2008 2:16 am
It's pretty simple. Some light enters the block just to the right of the thin blocking object. After one or more bounces inside the object, some of the light happens to bounce out of the block just to the left of the blocking object.
Post by PureSpider » Sun Nov 23, 2008 3:16 am
Ah cool thanks for the explanation :)
Post by CTZn » Sun Nov 23, 2008 6:29 am
Just to make things clear: this effect is available in Indigo since sss mats were implemented, it's just a test, nothing new isn't it ?
What is the real distance between the two objects, are their surfaces coplanar (or could they be) ? Or must the distance be above the nudge value for this effect to show ?
[/lazy tester mode]
Post by Zom-B » Sun Nov 23, 2008 6:38 am
Is this a new example scene for Indigo? ;-)
The Speed for the red example is amazing, very nice :)
I would like to see some speed comparison between old & new code!
looking forward to 1.1.15, great work Ono!!
Post by OnoSendai » Sun Nov 23, 2008 6:48 am
CTZn wrote:Just to make things clear: this effect is available in Indigo since sss mats were implemented, it's just a test, nothing new isn't it ?
[/lazy tester mode]
The thin blocking object is exactly just touching the block.
Post by OnoSendai » Sun Nov 23, 2008 6:49 am
ZomB wrote:Is this a new example scene for Indigo? ;-)
Yes, it's a new example / test scene.
Post by CTZn » Sun Nov 23, 2008 12:55 pm
Ok thx. There is a strange but nice effect on the last pic, the left topmost edge is fading from blue to red along its length, is this a jpg artifact or physical effect, like cauchy coeff ?
Or should I not ask at all :mrgreen:
Photoguy
Post by Photoguy » Sun Nov 23, 2008 6:37 pm
Well what Cpu is he running, then I'll be amazed.
22 minutes for 1000 spp is great!
Hellstorm
Post by Hellstorm » Sun Nov 23, 2008 11:18 pm
CTZn wrote:Ok thx. There is a strange but nice effect on the last pic, the left topmost edge is fading from blue to red along its length, is this a jpg artifact or physical effect, like cauchy coeff ?
Yeah. There's also some cyan color on the lower left corner of the cube, directly next to the watermark.
Post by Zom-B » Mon Nov 24, 2008 1:23 am
Photoguy wrote:Well what Cpu is he running, then I'll be amazed.
Well a Intel 6600 Quad Core afaik...but the point is that SSS seems to be much slower atm. Therefore a speed comparison would be nice :-)
Users browsing this forum: No registered users and 207 guests
