Indigo on Mac
Indigo on Mac
It's possible?
There is something like X11 software?
sure..
1. download and install latest xquartz, version 2.3.1
2. download and install Darwine 1.0 (which is mac version of Wine), i suggest 'Stable build of Darwine 1.0.1 for Leopard, with Freetype 2.3.7 and FontForge py25-20080828.'
3. run indigo.exe with WineHelper.app which you find in /Applications/Darwine
my experience is, running osx and wine is pretty comparable with running on windows, in indigo renders one hour here or one hour there doesn't really matter
i dont know if it is possible to start indigo from blendigo, without modding blendigo. i remember it recognizes only linux or win, so i choose not to start indigo, save files and then run indigo_console from terminal eg: without gui which is faster..
to do so you have to create '.profile' text file (no extension) in your home directory (/Users/YOURUSERNAME) which contains
which is default path to wine binary install location of darwine builds i mentioned above, and this is needed for easy running wine from terminal. than i have got folder /render in the root of disk, with indigo installed (/render/indigo)
i do simply:
and indigo will start rendering without unnecessary gui for final rendering and a bit faster of course. you can read log in terminal and time to time check png in renders directory
c.
export PATH="$PATH:/Applications/Darwine/Wine.bundle/Contents/bin"i do simply:
cd /render/indigo
wine indigo_console.exe RELATIVEPATHTOSCENE.igsc.
On my mac (leopard) indigo_console.exe works correctly via wine.
Did some body try with skindigo?
I can't get it working.
i post detailed explanation on this post:
http://www.indigorenderer.com/joomla/fo ... 5312#65312
I get working blendigo editing
/Applications/blender/blender.app/Contents/MacOS/.blender/scripts/bpydata/IndigoWrapper.conf
but partially.
witch version of blendigo and indigo do you use?
but partially.
Users browsing this forum: Ahrefs [Bot] and 50 guests
