tannerw_2010
by tannerw_2010 » Fri Sep 26, 2008 11:16 am
Thanks I got the the problem Solved! Just one thing though.
The Grass seems very "unrandom" because I couldnt find the Make Real Modifier anywhere.... I googled it up, and I think I did everything right as far as to try getting the make real modifier to show up, but nothing....
Thanks though
MSUdom5
by MSUdom5 » Fri Sep 26, 2008 12:17 pm
It's not a modifier. In the 3dview window, it's under Object->Clear/Apply->Make Duplicates Real
tannerw_2010
by tannerw_2010 » Fri Sep 26, 2008 11:18 pm
Here is my result without a random rotation (took too long to convert into real objects)
A little dissapointing to say the least, but its a start.... Tell you the truth, doesnt even look like grass imo... lol
WytRaven
by WytRaven » Sat Sep 27, 2008 1:48 am
Looks like a really short pine plantation
but you're right it is a start
"A foolish consistency is the hobgoblin of little minds..." - Emerson 1841
MSUdom5
by MSUdom5 » Sat Sep 27, 2008 3:11 am
Tanner, looks really nice! Great start! Is each blade of grass a separate mesh? If so, you might want to consider a slightly different approach, similar to this one:
http://www.indigorenderer.com/joomla/fo ... sc&start=0
which uses planes and alpha-mapped textures. This will reduce the geometrical complexity of your scene (fewer meshes, and the plane won't have to be subdivided nearly as much.
Users browsing this forum: Google [Bot] and 23 guests
