by CTZn » Fri Aug 15, 2008 1:03 am
Borgleader wrote:Well that definitely looks better. But I'm puzzled as to why the whole image still looks extremely grainy at such a high spp count. I mean at 1259 i would normally expect the image to look clearer.
1: short focal (implies DOF)
2: glossy transparent. Ono stated its behaviour could be assimilated to a bug (too much noise if I understood correctly).
Is your bottle really glossy ? IIRC it's not (good perfume choice
by CTZn » Fri Aug 15, 2008 7:49 am
Damn it's glossy !
Huh !? Apart using an very high frequency fbm for bump, no
Woodie
by Woodie » Fri Aug 15, 2008 3:09 pm
First keep it in Focus. It is definitely out of focus.
hstokholm
by hstokholm » Tue Aug 19, 2008 10:08 pm
A tiny tiny update
I'm getting a bit bored with this project, so i will almost call this finished.. I need to get the text more sharp, and maybe lighten up the background a little.?
- gio.png (183.86 KiB) Viewed 8722 times
Like a jigsaw piece without a puzzle
by fused » Tue Aug 19, 2008 10:21 pm
still looks like its out of focus.
very photo real!
hstokholm
by hstokholm » Tue Aug 19, 2008 10:24 pm
Thanks fused
Yes out of focus, but I don't understand it.. I set the focus distance in blendigo to match the front of the bottle.. Will try with a higher f-stop next time...
by PureSpider » Wed Aug 20, 2008 12:44 am
use autofocus?!
hstokholm
by hstokholm » Wed Aug 20, 2008 1:27 am
Autofocus is on
I am rendering now with a much higher f-stop and it looks better.. But hard to say on this slow slow laptop
by CTZn » Wed Aug 20, 2008 1:39 am
Dunno if it will help regarding speed, but you can maybe try to put the camera further from the bottle and give it a smaller angle of vision. The "in focus" zone should then be wider depth wise if I understand correctly.
The result is very good already I think
zsouthboy
by zsouthboy » Wed Aug 20, 2008 3:37 am
CTZn wrote:Dunno if it will help regarding speed, but you can maybe try to put the camera further from the bottle and give it a smaller angle of vision. The "in focus" zone should then be wider depth wise if I understand correctly.
The opposite is true, CTZn. Wider angle of view = more DoF.
cpfresh
by cpfresh » Wed Aug 20, 2008 4:09 am
i cant believe this bottle is still out of focus ... :0
hstokholm
by hstokholm » Wed Aug 20, 2008 4:30 am
cpfresh wrote:i cant believe this bottle is still out of focus ... :0
It is not anymore
Give this computer 10 more hours and I can show you
by CTZn » Wed Aug 20, 2008 5:18 am
zsouthboy wrote:CTZn wrote:Dunno if it will help regarding speed, but you can maybe try to put the camera further from the bottle and give it a smaller angle of vision. The "in focus" zone should then be wider depth wise if I understand correctly.
ah right, I'm telling a lot of bullpoo lastly.
hstokholm
by hstokholm » Wed Aug 20, 2008 8:44 am
If no one has big problems with this picture I think i will let it run and call it the final.. I have my first day at the university tomorrow, and want to have this finished
- gio.png (581.59 KiB) Viewed 8617 times
