Getting CPU and Fan stats without MBM or Everest
Post by PureSpider » Sat Aug 09, 2008 8:35 am
Hi guys!
I've been searching for the whole day for any clues on how to do this now, but wasn't able to find anything.
So I'm asking here...
How can I get the CPU Temp and Fan RPM stats without using Motherboard Monitor or something similar?
How do they do it?
I've tried with the GiveIO.sys but I only get rubbish for the adresses/don't know which addresses I should read from...
Any help would be greatly apreciated!
€dit: TO get this clear... I can access any address using GiveIO.sys, I just can't figure out the right ones.
jurasek
Post by jurasek » Sat Aug 09, 2008 9:44 am
install linux and type sensors;)
greetz,
jur
Post by PureSpider » Sat Aug 09, 2008 10:08 am
Huh? And then?
Does this work with cygwin, too?
dougal2
Post by dougal2 » Mon Aug 11, 2008 2:24 am
SpeedFan ?
Post by PureSpider » Mon Aug 11, 2008 7:34 am
... without MBM or Everest or Speedfan or any similar...
I need my own code for doing this as I don't want to display the results but do something different with it!
eman7613
Post by eman7613 » Mon Aug 11, 2008 9:42 am
that information is gotten from the mb, so your going to need a way to talk/listen to it. c++ does not inherently have this ability, so it depends on whether or not you want to do this for windows, linux, or os x.
for m$, somewher ein that big heep of api & visual studio there is probably an api to do it that may or may not be useful.
for linux, there are probably several diffrent packages that provide acess to get that information
for mac, well good luck i have no clue :P
but all in all, your"own code" for this will be different for each platform you are writing it for.
Yes i know, my spelling sucks
zsouthboy
Post by zsouthboy » Mon Aug 11, 2008 1:13 pm
Pure you're going to have to use SMBUS information to get those, and the addresses and information vary by implementation.
Post by PureSpider » Tue Aug 12, 2008 4:03 am
eman7613
There is an API for it, called WMI; Which needs to be supported by the mainboard drivers... and in 90% it isn't... that's the case for me, too =/
zsouthboy
That's right, I just dont know how to get or use them...
€dit: My SMBus is at address 0290 (hex)... now, how to use this?
Lord of the Rings Junkie
Post by Lord of the Rings Junkie » Thu Aug 14, 2008 7:45 am
Restart your computer and go into BIOS. CPU and fan stats are usually somewhere in there.
I imagine that's not the solution you want, though.
Post by PureSpider » Thu Aug 14, 2008 8:38 am
I cant use the stats in my BIOS within my own code, and thats what I want to ;)
But thx for the reply
zsouthboy
Post by zsouthboy » Thu Aug 14, 2008 10:06 am
Couldn't tell you how to get the information you want - perhaps a perusal of the manufacturer of the SMBUS chip's website would help? (It's possible they don't even tell you and instead want you to call their own DLL to get the information)
dougal2
Post by dougal2 » Thu Aug 14, 2008 10:31 am
Do you have to be doing this under windows ?
There's libsensors for linux (from which the 'sensors' program reads it's data).
sample output:
doug@quadUBUNTU:~$ sensors
it8718-isa-0290
Adapter: ISA adapter
in0:         +1.10 V  (min =  +0.00 V, max =  +4.08 V)
in1:         +1.30 V  (min =  +0.00 V, max =  +4.08 V)
in2:         +3.31 V  (min =  +0.00 V, max =  +4.08 V)
in3:         +2.96 V  (min =  +0.00 V, max =  +4.08 V)
in4:         +3.06 V  (min =  +0.00 V, max =  +4.08 V)
in5:         +0.85 V  (min =  +0.00 V, max =  +4.08 V)
in6:         +1.87 V  (min =  +0.00 V, max =  +4.08 V)
in7:         +2.94 V  (min =  +0.00 V, max =  +4.08 V)
in8:         +3.23 V
fan1:       1427 RPM  (min =    0 RPM)
fan2:       1558 RPM  (min =    0 RPM)
fan3:       1839 RPM  (min =    0 RPM)
fan4:          0 RPM  (min =   -1 RPM)
temp1:       +46.0°C  (low  =  -1.0°C, high = +127.0°C)  sensor = transistor
temp2:       +60.0°C  (low  =  -1.0°C, high = +127.0°C)  sensor = thermal diode
temp3:       -53.0°C  (low  =  -9.0°C, high = +127.0°C)  sensor = transistor
cpu0_vid:   +0.000 V
coretemp-isa-0000
Core 0:      +52.0°C  (crit = +100.0°C)
coretemp-isa-0001
Core 1:      +48.0°C  (crit = +100.0°C)
coretemp-isa-0002
Core 2:      +49.0°C  (crit = +100.0°C)
coretemp-isa-0003
Core 3:      +51.0°C  (crit = +100.0°C)
Post by PureSpider » Thu Aug 14, 2008 10:46 am
Yes unfortunately I need to do this under windows =/
zsouthboy
Post by zsouthboy » Thu Aug 14, 2008 10:55 am
Man, that's a lot of ISA adapters you got there dougal, you must be rockin that new VGA card with 512(!) kb of ram (1024x768?! amazing!)
:D
dougal2
Post by dougal2 » Thu Aug 14, 2008 11:06 am
lol yeah, most sensors still work over an ISA bus. crazy.
Users browsing this forum: No registered users and 65 guests
