Indigo 1.1.8
maybe he just forgot to add it to the docs and <exponent></exponent> in mats can take wavelegth independent parameters now.
i'd say its worth a try.
rendered overnight for a test and getting this error too after 7h30m rendering.Big Fan wrote:ok started playing
getting this fatal error
i==cdf.size()
any idea where thats coming from?
EDIT: seems to come from selecting env:lit by emitters for an emissive material but not actually having one set as emissive
normal scene no emitters, just diffuse colors as mats and sun/sky for lightning.
- Untitled-1.jpg (96.15 KiB) Viewed 7424 times
- ViennaLinux
jeah i once had to edit a 200mb igs file.
the only editor that was capable of copy and pasting was notepad++ and that was VERY laggy
would be better if every mesh would be in a subfolder called meshes but that would make the process of filesharing etc very complex.
- Borgleader
MS notepad usually crashes with 30-60Mb scenesViennaLinux wrote:jeah i once had to edit a 200mb igs file.
the only editor that was capable of copy and pasting was notepad++ and that was VERY laggy![]()
i had o use codeblocks
Pretty much the only thing worrying me tooOnoSendai wrote: They're not obsolete, I just haven't fixed that yet.
yeah.What's the use of all that fancy stuff, when you don't have a correct geometry to begin with
As stated that's an exporter's feature, Indigo can already take that using the <include> statement.would be better if every mesh would be in a subfolder called meshes but that would make the process of filesharing etc very complex.
<?xml version="1.0" encoding="UTF-8"?>
<!-- Exporter script from 3ds Max by Suvakas -->
<scene>
<!====== INCLUDE FILE THAT CONTAINS RENDER SETTINGS ======>
<include><pathname>indigo_gpu.max-settings.igs</pathname></include>
<!====== INCLUDE FILE THAT CONTAINS SCENE CAMERA ======>
<include><pathname>indigo_gpu.max-camera.igs</pathname></include>
<!====== INCLUDE FILE THAT CONTAINS SCENE GEOMETRY ======>
<include><pathname>indigo_gpu.max-geometry.igs</pathname></include>
<!====== INCLUDE FILE THAT CONTAINS SCENE MATERIALS =====>
<include><pathname>indigo_gpu.max-materials.igs</pathname></include>
Exporter Writers can detach the material settings and Indigo settings to separated igs files,Borgleader wrote:MS notepad usually crashes with 30-60Mb scenesViennaLinux wrote:jeah i once had to edit a 200mb igs file.
would be better if every mesh would be in a subfolder called meshes but that would make the process of filesharing etc very complex.![]()
also each mesh can be exported to a single igs, this is good for export performance and "notepad-material-tweaking"
Where have I seen this before... hmmm... ah.... Cindigo ftw
- Borgleader
Blendigo does it too i just hate having multiple filesZomB wrote: Exporter Writers can detach the material settings and Indigo settings to separated igs files,
Users browsing this forum: No registered users and 148 guests
