Black line
8 posts • Page 1 of 1
ahmadun
Black line
Post by ahmadun » Sun Jun 29, 2008 7:14 pm
I got a black line when i rendered a pool.[/img]
Post by Kram1032 » Sun Jun 29, 2008 9:58 pm
Looks like a Normal/-smoothing problem
try to make your volume a bit bigger than needed. It should intersect a bit with the pool walls. Also avoid sharp angles. ;)
ahmadun
Precedence
Post by ahmadun » Mon Jun 30, 2008 3:06 pm
That has been done, even setting up the precedence.
Yeah, the water was "Sprite" :wink:
I got the value of SSS from pdf indigo tutorial.
Post by Kram1032 » Mon Jun 30, 2008 11:03 pm
precedence shouldn't matter with diffuse materials - only speculars have a precedence value...
Just a thought, I guess it's *not* the problem but anyway:
Did you lower the MNCR to below 1000? I think, there are issues with very low MNCR and BiDir... Same with extremely low raybouncedepth.....
Btw: Your caustics are quite blurry and the reflections show a rather big lightsource... Try to make it a lot smaller if you want sharper caustics ;)
zsouthboy
Post by zsouthboy » Tue Jul 01, 2008 12:12 am
Can you post the .blend ahmadun? Sorry to ask you again, but i'm not sure what's causing that..
Post by CTZn » Tue Jul 01, 2008 4:30 am
Actually if the vater wolume is entirely smoothed you need to put the outermost faces into the wall; if they are partially only the smoothing will show. Theorically you need 2 full rows hidden to get rid of the artifact, if that's the cause of it.
ahmadun
thank you
Post by ahmadun » Sat Jul 05, 2008 3:15 pm
thank you all...
Post by OnoSendai » Fri Jul 18, 2008 6:22 am
Thanks ahmadun.
I've run into this bug before.
I'm not sure what causes it.
Users browsing this forum: Google Adsense [Bot] and 40 guests
