Blendigo for v1.1.1
pxl666
Post by pxl666 » Mon Jun 09, 2008 7:21 pm
hi indiblenders - did anybody can explain in few words how to use pigms within blendigo? do textures have to be mapped manually (uv unwrap?) and how to use material then (external?). tried to use bricks but i failed...
ViennaLinux
Post by ViennaLinux » Thu Jun 12, 2008 10:58 am
are you working on blendigo for 1.1.4 right now?
can i help you in some way with testing feedback?
Post by BbB » Thu Jun 12, 2008 7:56 pm
pxl666
You definitely need to UV-map your meshes. The pigm/igm won't work out the UV coordinates for you.
SmartDen
Post by SmartDen » Thu Jun 12, 2008 8:51 pm
Please, if somebody want to help testing - jump to our IRC channel
Check normals, dude!
Pinko5
Post by Pinko5 » Thu Jun 12, 2008 9:30 pm
:( I don't know the way to jump in IRC channel...
Luca.
Post by BbB » Thu Jun 12, 2008 9:30 pm
SmartDen: Did you see my exchange with Ono? Most of my scenes fail now using Blendigo for 1.1.1 and Indigo 1.1.2-to-1.1.5.
I get error messages about normals not being unit-length and also about UV-mapping errors. Indigo also crashes without error messages quite often. One of the scenes that fail under 1.1.5 is the Doc' material preview scene with a simple diffuse mat applied.
Help!
Pinko5
Post by Pinko5 » Thu Jun 12, 2008 9:40 pm
Quote BbB for UV-mapping errors Blendigo/Indigo releases.....
Luca.
pxl666
Post by pxl666 » Fri Jun 13, 2008 1:16 am
BbB wrote:pxl666
i did but how i use igm? i tried tu use igm as "external" matt file but it didnt work 4 me...
Post by BbB » Fri Jun 13, 2008 1:38 am
It didn't work in Blendigo for 1.1.1, I think. It may work in Blendigo for 1.1.5.
Post by Kram1032 » Fri Jun 13, 2008 4:50 am
Pinko, google-search "ChatZilla", install and then, as soon as you restarted Firefox, open ChatZilla and type in to the textbox:
irc://irc.enterthegame.com/indigo
Assuming, that you use Firefox, that is...
