Blendigo for v1.1.1
- aleksandera
- aleksandera
Here is the blend file. You probable need a IGS file
or so. I dont know if i can do this correctly.
Hope sombody else will.
- Disp-exp.rar
- (2.09 MiB) Downloaded 256 times
Hi Smartden,
Can you add the <c> parameter for displacement maps?
We can then set it to -<b>, so that the entire mesh doesn't appear to change positions.
Also, to the linux users that are getting the "module doesn't have bpy object" blah blah problem with Blendigo - Nortmobile and I have found a solution, I will explain what we did and post a modified Blendigo to see what Smart thinks.
- aleksandera
sure, i'll add it tomorrow. and it would be better if we could meet us in the irc channel or post me your blendigo per PM, but please dont post it in the thread, i thinhk it will cause more confusion.zsouthboy wrote:Hi Smartden,
And many thanks for working together to all tester and user of blendigo. It were nothing without you!
Check normals, dude!
- drBouvierLeduc
- aleksandera
- aleksandera
