Blends with Null / Alpha mapped materials
3 posts • Page 1 of 1
dougal2
Post by dougal2 » Tue May 20, 2008 1:25 am
I'm afraid to say that support for this in MtI is incomplete.
Blends between 2 materials are possible using a layeredShader. To use a blend map between the two, connect a file texture to the layeredShader's first child node's transparency attribute. (or to the Blend Factor attribute if you're using an indigoShader).
Blending with nulls is not possbile at present because there's no "null" type in indigoShader yet. This should be quite easy to implement, I'll do it soon :)
dougal2
Post by dougal2 » Tue May 20, 2008 1:30 am
I've just added the null material support to MtI - that was a trivial addition.
I'm not sure that a file texture on indigoShader's Blend Factor is supported yet though. I'll take a closer look later when I'm not at work.
vux
Post by vux » Tue May 20, 2008 2:10 am
thnx
OT
dougal2
maybe you need add text-field to indigoShader - the feature for Copy/Paste shader-text )
Users browsing this forum: No registered users and 46 guests
