by Kram1032 » Sat May 03, 2008 4:58 am
milk has hundrezs if I remember correctly...
water, having barely and scattering, is at roughly 0.001 - again if I remember correctly. I'm not sure anymore...
But actually all that info can be found in the forums
There where long threats about different liquids and their scattering values. - including some red wines, which could be what you're searching for.... (at least if you didn't descide to change the liquid^^) - search for "Merlot" or such and you should find it
remus
by remus » Sat May 03, 2008 5:00 am
cheers kram, i'll stop diluting this thread with newb drivel and go and do some rendering
alexmeyer
by alexmeyer » Sat May 03, 2008 5:46 am
Seriously, the best way (for me) to find the right values for things is to just change it a bit, do a preview render, then repeat as necessary.
Watch out for scene scale though! It can mess you up if you forget about it/change it later!
by Zom-B » Mon May 12, 2008 3:40 am
Here is another Image using the Studio Setup. The model wasn't done be me as usual, its from a very old renderchalange over at
www.c4dboard.com.
This was the first model I get rendered using Indigo 0.5 in 2006.
rusted wrote:your printer looks great with very balanced lighting.is it possible to post 3ds/obj file of studio setup.
Yes after Ono released the next Indigo version I'll release it
I'm just waiting for the env_map "light normalization".
- 12000spp
- ventilator.jpg (165.17 KiB) Viewed 5023 times
by Kram1032 » Mon May 12, 2008 4:07 am
That's a nice fan
by OnoSendai » Mon May 12, 2008 4:10 am
Yeah, much better than the last render
Photoguy
by Photoguy » Mon May 12, 2008 4:33 pm
I am a fan of that fan!
beta
by beta » Wed May 14, 2008 6:34 am
first try with dupliverts
render time 10-15 min.
material cr.nk
and a pencil dramatic fall!
4 hours to render 30 min to model...
- im1210695653.png (919.46 KiB) Viewed 4882 times
- im1210431562.png (864.18 KiB) Viewed 4882 times
by Kram1032 » Wed May 14, 2008 7:22 am
Oh comeon! You can do a better job at the dramaticness!
O.o A Suzanne Clone Army... Hopefully on the bright side....
crojack
by crojack » Wed May 14, 2008 8:26 am
I thought that pencil was an arrow pointing at something
beta
by beta » Wed May 14, 2008 8:38 am
hehehe... no it is falling but idk how could i add motion blur, DOF isn't good for that
but yeah i'll add some things more...oh! btw which method do u use for instancing i'm really getting cnfused with it... i used dupliverts but i'm not sure if that's the right way could some one easily explain or give a lik to a tutorial?
well here is a massive ball instancing A LOT of balls(only a bit are shown here but there were a lot more) don't know how many polys or anything cause it doesn't tell cause of the dupliverts... 30 min. rendering
later!
by Kram1032 » Wed May 14, 2008 9:17 am
alt+D to instance stuff... (if you don't need mass-behaviour like in your tests...)
beta
by beta » Wed May 14, 2008 9:32 am
mmm yep but if i press alt+d all i can do is duply one time so doing it one by one should by a pain in the ass!
am i missing some inputs or something?
thx in advance!
P.S: i don't think i should open a new post so... can someone help me with skins? i'm pretty lost... read the documentation(both indigo and blendigo) but there's no much info...and i get almost black skins...
by CTZn » Wed May 14, 2008 3:46 pm
by BbB » Wed May 14, 2008 5:59 pm
Guys, try not to upload .pngs if you can. They just take hours to load... Convert to jpgs instead.
Users browsing this forum: No registered users and 116 guests
