Blendigo for v1.0.9
Vanessa07
Post by Vanessa07 » Mon Apr 21, 2008 9:38 pm
Hi Smart
the blended material with null doesn't work with 1.0.9, I tried with 1.0.8 and it works
Thanks :D
pxl666
Post by pxl666 » Thu Apr 24, 2008 8:44 pm
smarty? ive got a small request - would u consider adding an option for setting global network share for textures - as u cannot select network shares within blender and this would be very useful - regarding rendering on multiple machines which normally requires to copy textures to a render slave. otherwise one has to change paths within .igs file - what in case of heavy scene is very difficult and slow...
hope i made myself clear
cheers m8s
SmartDen
Post by SmartDen » Thu Apr 24, 2008 8:45 pm
Vanessa07 wrote:Hi Smart
Thanks :D
you make something wrong. it works good for me:
Check normals, dude!
Vanessa07
Post by Vanessa07 » Thu Apr 24, 2008 9:03 pm
Thx I don't understand where I was wrong, it works fine know :?
Post by BbB » Thu Apr 24, 2008 9:21 pm
Hi Smart. What about no bump maps getting exported with Oren-Nayar?
SmartDen
Post by SmartDen » Fri Apr 25, 2008 12:33 am
BbB wrote:Hi Smart. What about no bump maps getting exported with Oren-Nayar?
Oh, sorry, you've right. I don't have seen your posting :)
I have fixed and uploaded blendigo
Post by BbB » Fri Apr 25, 2008 12:41 am
Cheers Smart. You're the best.
Two other things. No big deal but maybe you could look at them for the next update:
1) The gamma on the exponent map in the phong setting is set at 1 by default. I think it should be 2.2 as most exponent maps don't show any effect with such a low gamma value.
2) The B value in the exponent channel is clamped at a maximum of 10,000. Would it be possible to make this value higher?
Keet it up!
Pinko5
Post by Pinko5 » Fri Apr 25, 2008 9:18 am
:D
Luca. ;)
SmartDen
Post by SmartDen » Fri Apr 25, 2008 9:23 pm
BbB wrote:Cheers Smart. You're the best.
Keet it up!
next update will be fixed ;)
Post by BbB » Fri Apr 25, 2008 9:58 pm
Cheers mate. You're a darling.
pxl666
Post by pxl666 » Fri Apr 25, 2008 10:13 pm
once again
cheers m8s
SmartDen
Post by SmartDen » Fri Apr 25, 2008 11:25 pm
pxl666 wrote:once again
cheers m8s
i don't understand what you mean. let zs talk in irc or in the chat box, so you can explain it me
pxl666
Post by pxl666 » Sat Apr 26, 2008 12:09 am
cheers m8s
oh i didnt notice chat request - i'll explain :
i use indigo on my home network - i dont want to copy textures on my slave machines so i used this script:
start /belownormal /d \\Pxl666dell\dell_share3_data\data\works3d\INDIGO\indigo_v1.0.9_3\indigo_v1.0.9_3 indigo_console.exe "default.igs" -t 2 -n s -h pxl666DELL:7777
and it would start indigo on local machine (slave) from remote machine (master) without copying any files (not even indigo) - this script worked wonderfully until i installed newest indigo and blendigo...
i dont know what happened but i figured that the key is to set network share paths so indigo would search within them instead of absolute or relative paths.
so i would map texture directory on my master machine as i.e:
\\Pxl666dell\dell_share3_data\data\works3d\textures
and map this directory within blendigo so indigo (from any of slave machines) would look for it and load texture from network share.
this is because i can't set network share within blender and i would have to type it manually within blendigo or alter igs file by hand - both are pretty painful and slow
of course if u can see any other solution for this - ure more than welcome!
SmartDen
Post by SmartDen » Sat Apr 26, 2008 1:22 am
just link you network share folder as a drive on the remote machine and - voila you can set share paths in blender and so in blendigo and indigo too ;)
P.S. hope this will help, because i couldn't test it
pxl666
Post by pxl666 » Sat Apr 26, 2008 2:13 am
SmartDen wrote:just link you network share folder as a drive on the remote machine
but how can this be done?
Users browsing this forum: Ahrefs [Bot] and 64 guests
