Cindigo 1.0.9
Post by fused » Tue Apr 22, 2008 6:45 am
uploaded the new version, not sure, but there may be bugs with relative paths.
Post by pixie » Tue Apr 22, 2008 6:54 am
fused wrote:still, im not convinced. using the standard render output path? and export all cameras everytime? (if i get you right) doesnt make much sense to me, the user should have the contol about it.
If user uses the stage object is a clear sign he's using and organizing a scene with a clear and structured organization. Cinema manages scenes in a given way why not use it altogether instead of reinventing the wheel? New users would feel more at home and old user wouldn't have to do things differently weather they are using indigo or cinema.
When you export and give the project a name it saves the camera being used, it might as well save them all, it wouldn't take the user any control just the hassle of naming it (which could be made by key's time or by cameras name easing the scene organization). When I talk on using render output path I do it so that the same data doesn't have to be written twice, after all what you want is the output scene, why bother if it's Cinema or Indigo rendering?
fused wrote:also, when i export and run, wich one gets started? all? and what happens, when i want to export an animation? (when animation support is ready).
Well both my examples and the way stage object works rely on animation so there's no way to avoid it, as for which one who would get started? Being multiple scenes I would go for (a) none whatsoever, akin to what currently the default procedure of cindigo exporter (b) if a limit is given do it batch mode. b) seems the sensible option in an animation, (a) if all cameras are indeed different from each other.
Post by fused » Wed Apr 23, 2008 10:51 pm
hmmm... you convinced me. kind of.
the solution of yours is complicated and because cindigo doesnt support animation for now, i will put it in the camera tag - for now.
@all:
in case you didnt know: if you check "start as network master" in the export dialog, cindigo copies all textures to a sub-dir called textures.*scene-name* and the uses them.
Post by pixie » Thu Apr 24, 2008 3:38 am
Since animationa isn't yet working it would a be a bit difficult to implement, but once the framework is built I guess it will get a major bump on functionality, for once one could automate a lot. :)
Post by fused » Thu Apr 24, 2008 9:15 am
I uploaded a new version. new features/fixes:
* added german translation
* support for -o parameter (in the camera tag under "output")
* fixed blend material issues with blend maps
if you want to blend to a null mat, just leave on of the materials empty.
Post by pixie » Thu Apr 24, 2008 10:36 am
Some problems I stumbled on:
Indigo scene exported output:
    <material>
        <name>bb</name>
        <blend>
            <a_name>Mat</a_name>
            <b_name>Trans</b_name>
            <blend_map>
                <uv_set>default</uv_set>
                <path>boingmask.png</path>
                <exponent>1</exponent>
            </blend_map>
        </blend>
    </material>
Exported IGM output:
    <material>
        <name>bb</name>
        <blend>
            <blend_map>
                <path></path>
            </blend_map>
        </blend>
    </material>
Both lacking the blend factor and in second case also the path.
Post by fused » Thu Apr 24, 2008 9:24 pm
blend factor fixed.
the second one is strange...
having a look at it right now. upload soon.
Post by fused » Thu Apr 24, 2008 9:52 pm
fixed and uploaded
WLAD
Post by WLAD » Fri Apr 25, 2008 2:02 am
cool somthing to play with :D
Post by PureSpider » Fri Apr 25, 2008 2:40 am
Got another bug...
When you have a "not C4D" material (fry or vray) in the mat manager and try to convert the mats for indigo C4D crashes
just ignore the materials that are not C4D ones while converting the mats?
Post by pixie » Fri Apr 25, 2008 3:36 am
If I'm not mistaken it happens also with sky textures..
Post by fused » Fri Apr 25, 2008 6:26 am
ill have a look at it.
Post by fused » Fri Apr 25, 2008 6:53 am
found it, think i fixed it. wil be fixed in the next update.
Post by fused » Fri Apr 25, 2008 8:52 am
updated, should not crash on non-standard materials. some other small fixes, maybe you notice :)
Post by fused » Fri Apr 25, 2008 9:46 pm
hey,
here's a little preview of whats coming:
Locked
Users browsing this forum: No registered users and 66 guests
