Indigo 1.0.5
alexmeyer
Post by alexmeyer » Wed Jan 16, 2008 6:46 am
@ZomB:
Ono explained the "splat filters" in the post... I don't know if I completely understand it, but if you try a render, you'll see the noise looks different. As he said, it's how it "splats" the samples onto the image. (someone correct me if I'm wrong btw...)
This topic explains the "packed" scene files. What it does is zips the scene file, and any external resources (textures, etc.) into one file, so they're not external anymore. And yes, I think that'd be very useful for network rendering, as you'd only have one file.
Kosmokrator
Post by Kosmokrator » Wed Jan 16, 2008 7:07 am
i dont know if an other thanx counts......but a realy big bravo and thnx Ono....!!!
Olis
Post by Olis » Wed Jan 16, 2008 7:30 am
Breathtaking!
crojack
Post by crojack » Wed Jan 16, 2008 7:31 am
Sweet!
Post by lycium » Wed Jan 16, 2008 7:50 am
minor thing: you seem to be missing a clamp for the rgb values before png saving (screeny attached).
anyway, indigo now matches the output quality of my renderer; good job as always :)
rgigante
Post by rgigante » Wed Jan 16, 2008 8:21 am
Thanks Ono.
Once again great stuff added.
Best regards, Riccardo.
alexmeyer
Post by alexmeyer » Wed Jan 16, 2008 8:44 am
Hey, I was just trying to test the render region stuff... and it's not working right (it could be user error, but I don't think so...) I started a simple cornell scene for a minute, then tried to render a small section of it.
It didn't render all of the section (left some space on the top and right sides), and it doesn't look right either. It's all blown out.
Pinko5
Post by Pinko5 » Wed Jan 16, 2008 8:47 am
Txn ONO!!!
Luca.;)
tungee
Post by tungee » Wed Jan 16, 2008 8:49 am
Ono Big Thanx :D
Thanx for the Mitchell also!
Youn
Post by Youn » Wed Jan 16, 2008 10:15 am
alex I had similar results with reinhard tonemapping, so i tried linear and it seemed to be fine. of course, also try rendering to igi ;)
Wedge
Post by Wedge » Wed Jan 16, 2008 10:33 am
Thanks Ono! :)
Post by OnoSendai » Wed Jan 16, 2008 2:59 pm
Ah yes, one thing about using a render region is that you can't use Reinhard tonemapping. This is because the result of Reinhard tonemapping depends on the average luminance of all the pixels, which will change if you just render a particular region.
So if you want to use render regions, use linear or camera tonemapping.
Post by OnoSendai » Wed Jan 16, 2008 3:00 pm
lyc wrote:minor thing: you seem to be missing a clamp for the rgb values before png saving (screeny attached).
d'oh, thanks for spotting that Lyc.
Do you mean that you use MN in your renderer?
jurasek
Post by jurasek » Wed Jan 16, 2008 3:21 pm
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: Normal was not unit length. (In element 'mesh', around line 476332, column 5)
what 'normal was not unit lenght' really mean?:)
scene open well with 1.0.4
greetz,
jur
alexmeyer
Post by alexmeyer » Wed Jan 16, 2008 4:26 pm
@Ono: D'oh, of course, thanks... I guess if I had thought through it better, I would have figured it out. :oops:
Might want to add that to the first post, just so other people don't slip up on that.
Now I just have to get a feel for linear and camera... haven't really used em yet... :P
