Blendigo for v1.0
Pinko5
Post by Pinko5 » Sat Dec 01, 2007 4:18 am
little wow Smart!!!
Luca. ;)
Macrob
Post by Macrob » Sat Dec 01, 2007 4:47 am
SmartDen wrote:little update with obstacle map
whatever this may be :roll: :?:
dougal2
Post by dougal2 » Sat Dec 01, 2007 4:54 am
obstacle map is a monochromatic image which applies "dirt" etc to the camera lens. it basically messes with the focus, and has an influence on how glare spreads out.
Macrob
Post by Macrob » Sat Dec 01, 2007 5:19 am
Ok, thanks!
I guess you are right for sure, but ...
I still don´t get it :oops:
SmartDen
Post by SmartDen » Sat Dec 01, 2007 6:07 am
Macrob wrote:Ok, thanks!
Just read the Indigo 1.0.4 thread ;)
palawat
Post by palawat » Sun Dec 02, 2007 11:53 pm
wow, this is definitely the render engine i'll try and play with and the really nice community.
after reading many treads, THANKS SmartDen. you're the man !!!
Cheers,
Post by Kram1032 » Mon Dec 03, 2007 4:18 am
welcome palawat :)
airxart
Small request
Post by airxart » Mon Dec 03, 2007 4:53 am
Hi SmartDen. Thanks again for the exporter.
I was wondering if you could continue to name the Indigowrapper.conf
like you did in with ver.1.0.1 (Indigowrapper101.conf)
That way I can leave the other versions intact.
If not, I will just continue to edit the .py & .conf :D
I know the less you have to edit a file the better & I understand if
you don't feel this is a reasonable request.
Thanks for your time.
Eric
Post by Kram1032 » Mon Dec 03, 2007 4:55 am
it could be conf0.8 conf 0.9 conf1.0 conf x.y :) - but not for minor updates
palawat
Post by palawat » Tue Dec 11, 2007 8:07 am
One little problem here. i use Blender 2.45, Indigo 1.0.1, Blendigo v104 and Python 2.5.1. After my first play with Indigo, I got this;
Fatal error;
SceneLoaderExcep: Found unexpected element 'aperture_shape' in element 'camera'. (Around line 50, column 9)
One thing that doesn't match the requirement is Python 2.5.1. Should I instead use 2.5?
I'm running on Pentium 4, 3.0 GHz, HT, 2.56 GB Ram.
Cheers,
Post by Kram1032 » Tue Dec 11, 2007 8:10 am
Downloading Indigo 1.0.4 or Blendigo 1.0.1 will fix that ;)
The version numbers are supposed to match :P
palawat
Post by palawat » Tue Dec 11, 2007 8:33 am
Thank you very much, Kram1032. I've DL Indigo 1.0.4 and it works :D
Kram1032 wrote:The version numbers are supposed to match :P
I'll keep that in mind.
Cheers,
ViennaLinux
Post by ViennaLinux » Tue Dec 11, 2007 9:18 am
@SmartDen : maybe you should always post a screenshot of the exporter in the first post ... some are afraid because the dont know what they can do with this masterpiece of exporter ^^
ViennaLinux
Post by ViennaLinux » Tue Dec 11, 2007 9:22 am
ohh another thing i forgot.
you can run indigo with wine...
1) can you run indigo with darwine (under mac os x)?
2) can i get blendigo into blender in mac os x?
Post by Kram1032 » Tue Dec 11, 2007 10:15 am
AFAIK, Blendigo should work on any system, if there is a Blender version for it, complied with Python 2.5...
Indigo is an other questions, but I saw some posts, that ppl got it working.
I think, it somehow even worked with wine :)
Oh, and the exporter didn't change that much. It wouldn't be too useful, to only add a screenshot.
Keeping in mind the matching version numbers is better ;)
