Indigo 0.9 test 8
lol just a folder name, I have mini folders inside with other test versions which I just copy the contents over into the folder and overwrite to use different versions
in any case it doesn't work, Indigo thinks I'm trying to render the PNG!
I think it would be better if you can just run indigo normally and when you load up a PNG if spits out the meta data.
Easy for everyone, don't have to bother with command lines!
LOL not for me
Indigo Renderer v0.9 test 8, Windows 32-bit Release build.
SSE present.
SSE2 present.
SSE3 not found.
Scene file path: '--dumpmetadata'
Using working directory path ''.
Loading Scene '--dumpmetadata'...
SceneLoaderExcep: failed to open XML doc from path '--dumpmetadata': Failed to open file
Fatal Error: SceneLoaderExcep: failed to open XML doc from path '--dumpmetadata': Failed to open file
you should startCoolColJ wrote:LOL not for me
SSE present.
SSE2 present.
SSE3 not found.
indigo_console.exe --dumpmetadata your_render.pngstill doesn't work, a window pops up and dissappearsSmartDen wrote:you should startCoolColJ wrote:LOL not for me
SSE present.
SSE2 present.
SSE3 not found.
Fatal Error: SceneLoaderExcep: failed to open XML doc from path '--dumpmetadata': Failed to open fileCode: Select all
you need to open a console first. So go to your start menu and use the "Run" option. Type "cmd.exe" witout the quotes to launch a console. Navigate (via dos commands) to your indigo folder and then use "indigo_console.exe --dumpmetadata myimage.png".
- drBouvierLeduc
You can use spherical .float maps with indigo x64.delic wrote:So no environnement maps in indigo 64bits ? (..)
Use hdrshop to convert latlong .hdr to spherical .float (image -> panorama -> panoramic transformation, then "source image:latitude/longitude" and "destination image:mirrored ball", then "save as -> raw binary floating point".
I agree converting all your maps is a bit of a pain in the ass, and furthermore you have to type each map width in your exporter.
I hope exr support gets back in x64 for windows with indigo 0.9 final.
