Another test of Indigo and Maxigo (Thanks to Suvakas).
Time render: 8h on AMD X2 4200 2 thread
i've put a plane outside with a panorama jpg but with exit portal don't works and render a classic sky.
I want to try a flesh lamp test, how can i make it?
Meshlight? Settings?
Thanks to all
Livingroom test
Livingroom test
- Soggiorno.jpg (507.35 KiB) Viewed 4989 times
Re: Livingroom test
Hey gradozero.... nice Picture!gradozero wrote:Another test of Indigo and Maxigo (Thanks to Suvakas).
Thanks to all
Maybe the ground is a little to reflective and the bump mapped splits/grooves (?) on the ground shouldn't be that fat.... maybe!
For Exit portals every mesh behind it doesn't get rendered (like a plane with your panorama), only lightsources like sky or env maps are visible behind them...
for a fash light effekt you need a single very small light source, that faces only in "photo direction", to emit your room. tonemapping should do the rest. Check this thread for some more info
Users browsing this forum: Google [Bot] and 36 guests
