Livingroom test
4 posts • Page 1 of 1
gradozero
Livingroom test
Post by gradozero » Wed Oct 10, 2007 8:32 pm
Another test of Indigo and Maxigo (Thanks to Suvakas).
Time render: 8h on AMD X2 4200 2 thread
i've put a plane outside with a panorama jpg but with exit portal don't works and render a classic sky.
I want to try a flesh lamp test, how can i make it?
Meshlight? Settings?
Thanks to all
Re: Livingroom test
Post by Zom-B » Wed Oct 10, 2007 9:04 pm
gradozero wrote:Another test of Indigo and Maxigo (Thanks to Suvakas).
Thanks to all
Hey gradozero.... nice Picture!
Maybe the ground is a little to reflective and the bump mapped splits/grooves (?) on the ground shouldn't be that fat.... maybe!
For Exit portals every mesh behind it doesn't get rendered (like a plane with your panorama), only lightsources like sky or env maps are visible behind them...
for a fash light effekt you need a single very small light source, that faces only in "photo direction", to emit your room. tonemapping should do the rest. Check this thread for some more info
gradozero
Post by gradozero » Wed Oct 10, 2007 9:42 pm
Thanks ZomB,
there's a trick to use exit portal and see a background image or the only solution is don't use exit?
About the flashlight i read the thread but how many watt i've to use?
thanks
Post by Zom-B » Wed Oct 10, 2007 10:04 pm
I totally forgot that option mark told about here sorry
Users browsing this forum: No registered users and 52 guests
