Indigo 0.9 test 8
Indigo 0.9 test 8
Post by OnoSendai » Fri Oct 05, 2007 6:41 am
32 bit:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
64 bit:
changelog:
* added some camera parameter checks with exception throwing if incorrect.
* added correct external IOR for phong.
* New translucent / glossy transparent code
* Changed some sampling stuff, especially for phong materials.
* added metadata writing to pngs.
* added metadata reading from pngs with --dumpmetadata switch.
* added optional watermarking with indigo logo - added 'watermark' option in inifile and renderer_settings xml tag.
* fixed path weighting bug introduced in test 7
EDIT:
Please tell me about any bugs or issues you see!
If there aren't any show-stopping bugs then this will be released as 0.9 stable.
manitwo
Post by manitwo » Fri Oct 05, 2007 6:52 am
sweet :D
Post by suvakas » Fri Oct 05, 2007 7:09 am
Nice!
Correct external IOR? What's that?
[edit]
New logo?
zuegs
Post by zuegs » Fri Oct 05, 2007 7:15 am
PHANTASTICO :D :D :D
Can you tell us some details on this great news ???
BIG THX for your great work!
Post by OnoSendai » Fri Oct 05, 2007 7:21 am
Well, the phong material used to assume an external IOR of 1, which meant that e.g. an object with a phong material inside a glass of water (IOR 1.33) would be slightly shinier than it should have been.
Yes, I have a new logo.
Post by Whaat » Fri Oct 05, 2007 8:28 am
Thanks Nik! The new glossy transparent code looks WAY better! Awesome work! (Gotta luv those releases where there's no XML changes.. :lol: )
....are you sure the watermark option works when changing it in the inifile? It doesn't seem to be working for me.
jurasek
Post by jurasek » Fri Oct 05, 2007 8:30 am
Whaat watch your saved image...;)
greetz,
jur
Post by Whaat » Fri Oct 05, 2007 8:40 am
jurasek wrote:Whaat watch your saved image...;)
greetz,
jur
Aha! Thanks jurasek! :oops:
A quick comparison of the new version with the old. Same material settings. This is the SkIndigo frosted glass preset. Looks SO much better!
EDIT: added normal Specular glass for additional comparison.
Specular glass
old versions
Frosted Glass 09t7.png (93.7 KiB) Viewed 23029 times
version 0.9test8
Frosted Glass 09t8.jpg (51.3 KiB) Viewed 23028 times
zsouthboy
Post by zsouthboy » Fri Oct 05, 2007 9:10 am
Awesome!
It's great we'll won't have to add Indigo logos manually to our renders (to promote the engine) anymore (not that I ever did - but I will now :))
Can't wait to try the new glossy material out!
Thanks Ono!
CoolColJ
Post by CoolColJ » Fri Oct 05, 2007 10:29 am
great - I just took my Humanoid model with SSS skin to over 2000+ samples already in test 7 :(
Ono - does that path weight fix alters the render of lights/caustics behind glass etc?
Post by OnoSendai » Fri Oct 05, 2007 10:32 am
CoolColJ wrote:great - I just took my Humaoid model with SSS skin to over 2000+ samples already in test 7 :(
I'll post some skin results soon with some settings.
Yeah, hopefully it should fix those issues you were seeing.
rgigante
Post by rgigante » Fri Oct 05, 2007 10:49 am
Great news..
Thanks really for all your energy spent. Hope to test asap succesfully the incoming XSIndigo with 09.8.
Kindest regards, Riccardo
Phr0stByte
Post by Phr0stByte » Fri Oct 05, 2007 1:45 pm
Very bad news: wine once again is complaining about msvcr80.dll. I have it in the indigo dir and the system32 dir
wine-0.9.46
zsouthboy
Post by zsouthboy » Fri Oct 05, 2007 2:14 pm
It's working fine for me in Wine, Phr0st.
jurasek
Post by jurasek » Fri Oct 05, 2007 2:42 pm
Wine 0.9.36, fast as hell here.
greetz,
jur
Users browsing this forum: Ahrefs [Bot] and 117 guests
