Restart from Indigo Crash...
BennitoJuarez
I'm needing to know if there's a way to restart from where a previous render session left off when Indigo crashed... Help anyone? I've started using this program commercially along side Google Sketchup,
Welcome to the forums!
If you were in the middle of a render and you had "Save IGI" turned on, you can resume your render by typing in "Indigo.res" in the ruby console.
Select the IGI file (in your renders directory) and the IGS (indigo scene file) to resume the render.
Let me know if you need any more help.
Help! I am in the same boat right now and need to resume a render, not because of a crash but because of Vista's stupid auto-update crap restarting my machine (which is now turned off).
You say type "indigo.res" in the ruby console....um what ruby console??
I am using Indigo 64bit 0.9t7 on Vista64 Ultimate. I have checked the manual and can find nothing on resuming...
Thank you to SmartDen who helped me sort this out using IndigoChat on the home page.
The correct answer is from a command line navigate to indigo install folder and type "indigo.exe -r <relative path to igi> <relative path to igs>"
So for example it might be indigo.exe -r renders/im1190728126.igi default.igs
Thanks again SmartDen
BennitoJuarez
OK... New Problem... after choosing the *.igi and the *.igs to resume a rendering, the cmd window temproarily opens up and an error window pops up stating: cannot find indigo.exe. Do I need to specify the location of the Indigo.exe? If so... where do I input this information, or, do I need to move it into a location where the Ruby Console will locate it automatically?
I think you might have found a SkIndigo bug.BennitoJuarez wrote:OK... New Problem... after choosing the *.igi and the *.igs to resume a rendering, the cmd window temproarily opens up and an error window pops up stating: cannot find indigo.exe. Do I need to specify the location of the Indigo.exe? If so... where do I input this information, or, do I need to move it into a location where the Ruby Console will locate it automatically?
First, copy the two IGS files that SkIndogo creates (be sure to inlcude the -settings.igs file) to the Indigo directory. (assuming they aren't there already)
Then try typing "Indigo.res" in the Ruby Console again.
If this doesn't work, look for a file in your Indigo directory called "resume.bat" and post the contents of file so I can take a look.
