[bug] re "set" of exr map...
Kosmokrator
Post by Kosmokrator » Mon Sep 17, 2007 8:22 am
hi suv... an bug i found is: indigo exporter forgot the exr map i have set for an scene after the exporting......after the exporting when i press again the export button indigo crash in lag-long map...if i re ender the path of my exr map export and works fine....
i hope u understand what i mean.... :roll:
Post by suvakas » Mon Sep 17, 2007 8:26 am
Gotcha. I'll check it out tomorrow (if i have some time.. been real busy lately).
You're a good tester Kosmo :wink: 8)
Kosmokrator
Post by Kosmokrator » Sat Sep 22, 2007 8:01 pm
any news about this bug?u fix it? i think its not hard its some variable who not update correctly.....i work with exrs and its painfull to reload the map again and again! :)
Post by suvakas » Sat Sep 22, 2007 10:54 pm
Sry, I havn't looked at it yet. Messing around with particles at the moment. Will check it out soon.
filippo
Post by filippo » Sat Sep 22, 2007 11:19 pm
if for each render you re-select the exr map the problem it's finished
filippo
sorry for my poor language
Post by Kram1032 » Sun Sep 23, 2007 12:10 am
he said, it's a pain, to do that, filippo...
If the .exr needs a while to load, I can understand him ;)
Kosmokrator
Post by Kosmokrator » Sun Sep 23, 2007 12:28 am
itsn not realy painfull its boring and time-lose for me (and for every other max user)
imagine how many test renders u do for one image.....imagine exept for the material settings every time to re load the map again and again from some location in your disk..... :wink:
Post by Kram1032 » Sun Sep 23, 2007 12:58 am
yeah, I can understand you ;)
Post by suvakas » Sun Sep 23, 2007 8:28 am
Ok, I think i fixed it.
@Kosmo: Do you want to test it?
Kosmokrator
Post by Kosmokrator » Sun Sep 23, 2007 12:02 pm
yes i want to test it please...upload the new version please!!thnx a lot!
Kosmokrator
Post by Kosmokrator » Mon Sep 24, 2007 6:42 am
suiv where is the update???
yesterday i was drunk and i believe for this i cant find the update.....but and today still cant find it!!
(may im still drunk?) :roll: :oops: :lol:
Post by suvakas » Mon Sep 24, 2007 6:51 am
Sry, I forgot it completely.
Here is the main script file. Copy it to scripts\Maxigo and overwrite the previous Maxigo.mse
And please let me know if it solves the exr problem.
Maxigo.zip
(225.84 KiB) Downloaded 242 times
Kosmokrator
Post by Kosmokrator » Mon Sep 24, 2007 6:57 am
thnx a lot man!!!work fine now!
is there any other fix or update??
the file was 2-3 kb larger than the old.... :wink:
thnx again man
Post by suvakas » Mon Sep 24, 2007 7:07 am
Gotcha. Thanks!
Well.. there are some new stuff.
If model has no material applied, then it will be rendered using it's viewport color no mather what format is picked. (it only worked with xml before).
And there is also some unfinished stuff for better particle support. When i'm done with it then it should be possible to export particles into obj format.
filippo
Post by filippo » Tue Sep 25, 2007 7:37 pm
Thanks.....wonderfull work...
filippo
