Blendigo for v0.9
Post by Kram1032 » Thu Sep 06, 2007 4:50 am
yeah, that's what I meant....
two swatches - one with your picked colour and one, how it will look like :D
Big Fan
Post by Big Fan » Thu Sep 06, 2007 11:22 am
ok I have another question:
what is the relationship between the rgb colour for gamma 1 and gamma 2.2?
ie are the gammas related by exponential factor or something... :roll:
EDIT: ok found it on wikipedia :wink: will see what I can do..
Big Fan
Post by Big Fan » Thu Sep 06, 2007 5:29 pm
ok here's a trial - its built on the Solidworks variant ATM cos I am more familiar with looking at it
the variant isnt all up to date and the includes stuff only mostly works and it has different previews arrangements so it is of limited use for usual users but you should be able to test the sss and absorb gamma with it
if it works :roll: and its what you want I'll try to make a similar thing for blendigo
EDIT removed as served purpose - not intended for real use
SURFiNG
Post by SURFiNG » Fri Sep 07, 2007 2:08 am
trying now
SURFiNG
Post by SURFiNG » Fri Sep 07, 2007 2:15 am
yayyy it worksss...
Anyways what about preview colour? I mean it must change when you change also the Gain factor, don't ?
Big Fan
Post by Big Fan » Fri Sep 07, 2007 8:25 am
hmm only one reply out of 8 downloads I guess people arent really that interested?
@SURFING well it hasnt been that way before..
I suppose I could do a hack to make it lighter or darker based on the gain..but it would be an approximation..
just using the preview sphere it seemed a gain of 3 or so matched fairly well the colour displayed and rendered for absorption..and a gain of 100 for sss
the way these are set up is slightly backward too - cos you enter the opposite colour you see :roll: or at least I think its that way in smartdens blendigo
I am not sure there is any good way to arrive at a WYSIWYG for all situations
suggest you use the material preview to get things right before you render your full scene
Post by Kram1032 » Fri Sep 07, 2007 9:30 am
absorbtion / SSS gain can't really be predicted that way: it depends on the thickness of an object...
Big Fan
Post by Big Fan » Fri Sep 07, 2007 10:18 am
true kram ...hmmm maybe I will make a bigger object for one of my previews..
ok well I am not sure if the silence is because people dont want this , or it isnt right or they dont care or...I guess I'll leave it then for smartden to tackle at a later date
SURFiNG
Post by SURFiNG » Fri Sep 07, 2007 10:54 am
im really interested, i've found a couple more of menus like the new atmosphere and i like the work you did
CoolColJ
Post by CoolColJ » Fri Sep 07, 2007 11:42 am
here one day, gone the next :P
Big Fan
Post by Big Fan » Fri Sep 07, 2007 12:36 pm
well I am sure its not like people didnt see it :wink:
it wasnt for ongoing use - only feedback on a gamma solution
how many times a day are you here for instance..
or many other names I see in who is visiting
I'll bet 50 Blendigoists passed over it :roll:
only one person ( the original asker) says anything
Even kram says nothing about it so I guess he didnt bother either?
although I tried to give him a preview solution he thought would be a good idea
What would you make of that in my position?
does it look like users would like this or not?
these things take time to do :?
if there is no thumbs up feedback on stuff I am not going to spend even
more time putting it into smartdens blendigo and risk upsetting him and others for doing so
paulo_gomes
Post by paulo_gomes » Fri Sep 07, 2007 1:31 pm
late as always! link gone! :x
Big Fan
Post by Big Fan » Fri Sep 07, 2007 2:48 pm
thems the breaks... :wink:
CoolColJ
Post by CoolColJ » Sat Sep 08, 2007 12:17 pm
for some reason Blender scene files take much longer to warmup and get to rendering than ones generated by SKindigo and Cindigo
I wonder if its the XML format used rather than IGS...
or something else....
oogsnoepje
Post by oogsnoepje » Sat Sep 08, 2007 2:03 pm
Perhaps there's more data exported to warm up?
Users browsing this forum: No registered users and 46 guests
