Converting your RGB colour To NK
Post by Kram1032 » Fri May 18, 2007 4:23 am
hey, that's nice!
A whole arsenal on nk-colours :shock:
I dunno, if there is any way to prevent the interface to be too big, but what about simulatneous convertion?
you put in ONE type of values (i.e. rgb or nk) and all the rest will be added.
and instead of listing them all up (which is great, but uses a lot of space), you could add sliders, that put in the degree value. Those could be much more accurate than this per-degree-view.
Is it possible?
Also, a "switch view"-option would be great!:
This vview and the view with sliders, that I descriped :D
manitwo
Post by manitwo » Fri May 18, 2007 5:08 am
wow - great tinman!
your little prog is growing fast :D
Post by CTZn » Fri May 18, 2007 6:17 pm
I'm not productive yet with it, but indeed it has evolved quickly !
CoolColJ
Post by CoolColJ » Fri Aug 31, 2007 10:55 am
bump for this very useful program I just discovered for creating your own NK data files 8)
CoolColJ
Post by CoolColJ » Sun Sep 09, 2007 1:04 pm
thanks to this program I finally have some materials for my Alien stuff 8)
basic Phong doesn't really do the same thing.. tests of the same colour, varying the exponent of both from 1 to 1million
and IOR from 1 to 100 for Phong as well
The NK version only displays the colour in the highlight areas, but tends to be black in other parts. EVen though the NK plot doesn't show any black
A blend material of both would be interesting....
Now I can put the finishing touch on my Alien Artifacts scene and finalise a render after 3 attempts at it with Phong!!! :evil:
CoolColJ
Post by CoolColJ » Sun Sep 09, 2007 1:08 pm
now if you could vary the IOR for NK data on a overall level then we would be set.....
Post by Kram1032 » Mon Sep 10, 2007 4:37 am
nk is complex IoR, which means, as far as I understood it, it finds differently strong colours for different IoR... so, it is a matter of varying the position of some of the lines, I'd say...
(not sure, though)
CoolColJ
Post by CoolColJ » Mon Sep 10, 2007 7:46 pm
well dark colours have lower IOR when converted to NK.
I don't know how the the Reflection curves are calculated but they are all different for each colour you create
Post by Kram1032 » Tue Sep 11, 2007 1:34 am
I looked at the curves and my results are quite interesting, sometimes^^ - try 50% grey WITH gamma correction -> strange IoR curve :)
Xman
Post by Xman » Thu Dec 06, 2007 2:57 am
http://www.renderlight.co.uk/files/rna.zip
Hello everyone
This line can't download, can anyone give me a line can work?
Thanks all
SmartDen
Post by SmartDen » Thu Dec 06, 2007 3:11 am
If anybody can share last version?...
Post by Zom-B » Thu Dec 06, 2007 3:26 am
Try this link guys for a even newer version.
Here you go for Timan's thread regarding developement of this nice little tool...
Xman
Post by Xman » Thu Dec 06, 2007 3:56 am
Thanks you, Zomb
:D
filippo
Post by filippo » Thu Dec 06, 2007 11:26 pm
THE LINK DON'T WORK
FILIPPO :(
Post by Zom-B » Fri Dec 07, 2007 12:06 am
filippo wrote:THE LINK DON'T WORK
I'm sure you just missed my posting.... here you go!
The Name of this app changed, so did the link...
