Diffuse transmitter material
Post by Kram1032 » Thu May 17, 2007 9:46 pm
Kram1032 wrote:hum...
I guess, that's, 'cause of the behaviour of the diffuse transmitter:
it isn't a physically corret thing, but adds light it's own colour.
in that case, the coulour is aded many many times -> no more light :S
<- see? I already said that :P
Post by OnoSendai » Thu May 17, 2007 9:48 pm
It's not 'adding' light. It's multiplying/attenuating it.
Post by Kram1032 » Thu May 17, 2007 9:49 pm
yes, ok...
But basically, I said that :P
Post by OnoSendai » Thu May 17, 2007 9:57 pm
Behrendt
Post by Behrendt » Tue May 22, 2007 5:44 am
I got a problem with diffuse transmitter material. The lampshades all are blend materials between diffuse transmitter and diffuse. The tv-screen is a diffuse-transmitter material only. So without assigned material to the tv screen all works very well, but if I assign the diffuse transmitter material to the screen it seems to turn out the other meshlights. But have a look on your own.
Post by Kram1032 » Tue May 22, 2007 6:19 am
hum...
maybe, you should make the screen pic not haing pure whites :D
decrease the contrast by 2 should be enough, I guess, to give the pic at least SOME colour^^
the emitter behind the screen either shall be either 6500K (sRGB) or as it is a new one, I guess, 9300K (high efficacy computer screens)
it appears to be a brihtness problem... try one of two things:
1) make the light behind the diftrans "indirect" by just making the left and right wall and "up" and "down" emitters and the backwall a pure white diffuse,
2) lower either efficacy or gain (or Wattage), dependin on which mode you're using for it.
Maybe also 3)
making the space between diftrans and lightsource an SSS mat
and 4) comnine those things, 'til you're satisfied.
Behrendt
Post by Behrendt » Tue May 22, 2007 8:53 am
1)I don't understand solution one, would be nice if you could post this in our both native language :D
2) I tested around with the different light-types and it only seems to happen with a blackbody light but with the other light types I can't get any results.
3) Why should this affect the behaviour of the other mesh-lights?
4) I wish I could be
:D
Post by Kram1032 » Tue May 22, 2007 9:07 am
ok...
please excuse that german part:
__________________________________
Mach einen kleinen Raum in den Fernseher.
Statt nur EIN Mesh-Licht in Form eines Recteckes zu nutzen, gibst du an die vier, durch die Vertiefung entstandenen Seitenwände, vier kleinere Mesh-Lichter.
Die hintere Wand sollte ein reinweißes Diffus-Material haben.
___________________________________
thx.
The SSS idea is: the light is less straight, when it hits the diffuse transmitter and it also is less bright.
I actually meant that as "expansion" of 1) ;)
a new idea, which I have NO idea, what result it will give, is, blending the SSS with the diffuse transmitter.
That would be, like there was a "blur layer", before the actual pic appears.
And I guess, that should be rather realistic...
An other idea: two blends:
SSS in backpart to specular in front part (that may give a strange result, settings should be simmilar, besides the fact, that one is SSS and one iis pure transparent) and over that blend, add the difuse transmitter, by blending the blend with the diffuse transmitter ;)
Behrendt
Post by Behrendt » Tue May 22, 2007 9:15 am
I tried to play around with wattages but then then the screen turns to complete black -> other mesh-lights work well. :(
edit:
I think I got a good solution. I turned the Intensity of the Light inside the tv to 0.01 and increased the exponent of the diffus-transmitter material to 4. This works pretty well.
But I still have no clue how this settings influence the other mesh-lights?!
Wedge
Post by Wedge » Tue May 22, 2007 1:32 pm
I tested awhile ago and found that when one light is too strong or too powerful it sucks up all of the other lights power. :shock:
So you are not alone, this can happen sometimes.
Post by Zom-B » Wed May 23, 2007 1:30 am
Wedge wrote:I tested awhile ago and found that when one light is too strong or too powerful it sucks up all of the other lights power. :shock:
This is an classic Reinhard tonemapping issue!
Post by Kram1032 » Wed May 23, 2007 1:45 am
exactly.
If you don't get the correct setting of lights, you more or less are SUPPOSED to use linear tonemapping.
But I think, it's still simpler, to get it right with reinhard...
filippo
Post by filippo » Sun May 27, 2007 2:03 pm
wonderfull result...
this material it's very nice... :D
filippo
SzLaszlo
Re: Diffuse transmitter material
Post by SzLaszlo » Sat Sep 26, 2009 12:23 am
Hi ,
I try -Diffuse transmitter material-
This mat. work ( only color ) :
<material>
<name>LogoTDiff</name>
<diffuse_transmitter>
<albedo>
<constant><rgb>
<rgb>0 0 1</rgb>
<gamma>2.2</gamma>
</rgb></constant>
</albedo>
</diffuse_transmitter>
</material>
, but I use .jpg textura dont work :
<material>
<texture>
<path>*.jpg</path>
<uv_set>UVTex</uv_set>
<exponent>2.200000</exponent>
<a>0</a>
<b>1</b>
<c>0</c>
</texture>
<albedo>
<texture>
</texture>
</albedo>
</material>
I can't understand why :(
László
Post by CTZn » Sat Sep 26, 2009 1:02 am
try saving the jpg with another application, or even to a different format (png, tga).
Can you please report the Indigo error, it's important to answer you.
