Jonshi
by Jonshi » Tue May 08, 2007 6:18 am
Wath can i only render with Physical skylight without sunlight like a cloudy day??
Thanks
by Kram1032 » Tue May 08, 2007 6:25 am
If I get your question correct, you want to render a sunless sky - 'cause of clouds....
atm, (hopefully atm
) Indigo can't create random cloud-skys, so there are two ways for that.
One is extremely hard and not really senseful: modell clouds yourself.
the other one is much better:
use HDRi
manitwo
by manitwo » Tue May 08, 2007 7:25 am
no i think he only wants physical sky without sunlight.
Afaik the only way to do this is to set the sundir to "0 0 0". (open your igs/xml with an editor and change the numbers) - will give a dawn-like sky without sun.
by Kram1032 » Tue May 08, 2007 7:28 am
000 = not a sun pointing straight down???
manitwo
by manitwo » Tue May 08, 2007 7:34 am
sun with no direction
try it
by Kram1032 » Tue May 08, 2007 7:43 am
mhm...
Post the pic, then
I guess, it will look great
Jonshi
by Jonshi » Tue May 08, 2007 7:17 pm
Thanks I trying it with your sugestions...I don´t want clouds, only a day without sun, like when you put only an environment color in vray or turn off direct sunlight in maxwell... but without HDRi, something very simple.
Thanks again
by suvakas » Tue May 08, 2007 9:41 pm
You can't use environment color in current Maxigo version, but it will be included in my next release. Currently you can do it manually by replacing sky code in xml with background code. I don't remember the syntax at the moment. Maybe someone posts it for you...
Users browsing this forum: No registered users and 52 guests
