Alphabet Soup
14 posts • Page 1 of 1
eg2k6
Alphabet Soup
Post by eg2k6 » Sun May 06, 2007 6:51 pm
Its been awhile since I've done any 3D, so I return with a simple concept: Floating ABCs! :D
I was testing text and the randomizer script, and I thought it turned out pretty good. :twisted:
the DOF is a little strong tho...
modeled in blender, rendered with indigo 0.6 for 2 hours.
Alphabet Soup.png (361.5 KiB) Viewed 11807 times
Post by OnoSendai » Sun May 06, 2007 6:54 pm
Nice.
You're two version behind the current now! ( 0.8 ) :)
Post by Kram1032 » Sun May 06, 2007 8:12 pm
But 0.8 is still buggy.
You can use it, but 0.7 should be fine.
If 0.8 works, it's better, 'cause faster ;)
Looks cool 8)
If you can find a Suopletterlike Font, you could use it and do a REAL Soup :D
manitwo
Post by manitwo » Sun May 06, 2007 11:45 pm
great!!! :D
rendered with 0.8 that scene might be clean after a couple of minutes.
eg2k6
Post by eg2k6 » Mon May 07, 2007 3:56 am
just got 0.8t1, the GUI is awesome! :shock: no more changing .ini files, heh. :twisted:
are there any exporters for 0.8t2?
Post by OnoSendai » Mon May 07, 2007 4:02 am
0.8t2 is just a bug fix, any exporter for 0.8t1 should work.
eg2k6
Post by eg2k6 » Mon May 07, 2007 5:07 am
:( whenever i render the image, it turns blueish.
i have the background set to white, and the sky type set to 'background'. am i doing something wrong? im using Wedge's 0.8t1 blender exporter with indigo 0.8t2.
Post by OnoSendai » Mon May 07, 2007 5:10 am
You probably need to change the colour balance, if you're using a white background, set it to E.
eg2k6
Post by eg2k6 » Mon May 07, 2007 5:57 am
i decided to render this in 0.8t2, and it looks better. the render times are sooo fast heheheh...... :twisted:
modeled in blender, render with indigo 0.8t2 for 20 minutes.
Alphabet Soup2.png (398.77 KiB) Viewed 11658 times
Post by Kram1032 » Mon May 07, 2007 6:27 am
1/6 of time and 6* quality :D
dougal2
Post by dougal2 » Mon May 07, 2007 7:45 am
i prefer the higher contrast of the first image.
eg2k6
Post by eg2k6 » Mon May 07, 2007 8:00 am
:shock: i think the low contrast makes it look like they're floating in a cloud, instead of an open white abyss.
Post by Kram1032 » Mon May 07, 2007 8:20 am
I actually like both versions :D
Here is a recontrasted version
iamthwee
Post by iamthwee » Sun May 20, 2007 2:09 am
pretty simple abstract work. Looks fab tho!
