Don't use Vista, 'till SP1, if you can avoid it
Indigo 0.8 test 1
Thanks Nick! I will be eager to test my beach house scene as 0.8 unfolds.
I do have one question, I am somewhat confused on how to turn on/off which buttons:
Bidir / MLT / Hybrid
Bidir can be on/off no matter what MLT or Hybrid is?
MLT can be on/off no matter what Bidir is, but what about Hybrid?
Hybrid uses path tracing and MLT right? So if hybrid then MLT too? (or are MLT tags ignored once hybrid is on?)
Edit: Also Nick I wanted to tell you I am getting some strange error from bidir in the beach house scene. Would you like me to post a small image showing the result? I have been getting it since you enabled bidir, so it is not 8t1 that caused it.
Thx Nick
I didn't know I could use BiDir without MLT though. I always use both, and wondered why my scenes were longer to render with BiDir on as it was supposed to be faster.
So, BiDir only = faster render but BiDir + MLT = longer render ?
By the way, would it be possible, for confused people like me, to make a short topic explaining the aim of each algorithm and when to use it or not ?
The "metropolis" setting is ignored if "hybrid" is activated.
The "bidir" setting has still influence tho.
"rqmc" is always enabled.
Possible Combinations:
- MLT Mode: ("Metropolis"-true)
- Pathtracing Mode: ("Metropolis"-false)
- Hybrid Mode: ("Hybrid"-true)
- Bidir MLT Mode: ("Metropolis"-true, "Bidir"-true)
- Bidir Pathtracing: ("Metropolis"-false, "Bidir"-true)
- Bidir Hybrid Mode: ("Hybrid"-true, "Bidir"-true)
The last two modes are recommend.
I've been experiencing the issue of images turning black before, that was with 0.6t6. So Ono if there is an element you removed/desactivated since 0.6t6, and reactivated back for 0.8 then this may be related, hope that give an hint... there was no white spots with 06t6 tho (full black).
The image turns black if you use Bump maps with Hybrid mode. Somebody must post it in Bugs threadCTZn wrote:I've been experiencing the issue of images turning black before, that was with 0.6t6. So Ono if there is an element you removed/desactivated since 0.6t6, and reactivated back for 0.8 then this may be related, hope that give an hint... there was no white spots with 06t6 tho (full black).
Yes, so strictly speaking, it's not a direct/indirect partitioning of the integral, but a easy direct / hard direct + indirect partitioningIanT wrote:Re: Hybrid ... excellent choiceI did some testing with this myself a while ago and it seems Veach was indeed right
I assume you're still sticking with MLT for whole-sky sampling?
Ian.
- afecelis
Me too, scene going black after a couple of passes (with some white spots), trying to re-render in 0.8 a scene that rendered fine in previous versions. I sent the image to Ono to see if he can reproduce it.
- Kosmokrator
- afecelis
In case you guys also wanna grab the scene, here are the blend and igs files:
http://www.danielpatton.com/afecelis/In ... s/cube.zip
- Heavily Tessellated
Users browsing this forum: No registered users and 123 guests
