Indigo Exporter for 0.7t5 - beta release
Locked
Post by Kram1032 » Wed Mar 21, 2007 2:42 am
@ fused: don't use pure white as default mat! It would need longer ;) take a bright neutral gray ;) Paper ~85,4901961 grey ;)
manitwo
Post by manitwo » Wed Mar 21, 2007 4:08 am
@kram: i dont want to quote myself soo look at page 5 :)
the default color is already 0.85.
Post by Kram1032 » Wed Mar 21, 2007 4:55 am
ok^^
jackei
Post by jackei » Wed Mar 21, 2007 9:21 am
cool...thank you for the file. and i think i am crazy...=) the file is working with my exporter. i think it's my fault. and i think i know the problem. i selected the render method "pathtracing" and this isn't working....
thank you for your support.
jackei
Post by Kram1032 » Wed Mar 21, 2007 9:28 am
pathtracing should work (at least from indigo, don't know, if it works for the exporter) but most pics are looking better with MTL-Raytracing! (It's slower, but needed for most scenes, which don't have enough direct light)
Marcofly
Post by Marcofly » Thu Mar 22, 2007 4:20 am
First of all: THANK YOU EVERYBODY SOOOO MUCH for the great job! I stopped testing Indigo when the BL-Exporter didn't work anymore, now fused makes me happy again! ;-)
Unfortunately the exporter makes my C4d crash (both versions 9.6 and 10)..
if I open the test scene delivered with the exporter, or the 'exporter test.rar' of WLAD, they are exported correctly, and indigo runs ok. But if I click on the 'indigo render settings' tab, I get those error messages:
Symbol Type_latlong not found.. line 80
Symbol Type_spherical not found line 80
Error reading resource: file .......res-description-tmyrendersettingsexp.res line 88
I tried to add the two code-lines at the end of the tmyrendersettingsexp.str, asProtocultura suggested:
TYPE_LATLONG "Lat/Long";
TYPE_SPHERICAL "Spherical";
but I get the same message..
What am I doing wrong?
thank you and greets from Italy :D
Marcofly
Post by Marcofly » Thu Mar 22, 2007 10:01 am
i noticed a difference between
\res\strings_de\description\tmyrendersettingsexp.str
and
\res\strings_us\description\tmyrendersettingsexp.str
of a few lines at the end. i fixed that, now Cinema doesn't crash immediately when i ckick on the render setting icon (that works well now), but crashes when i try to save the exported file. I get this message:
does anybody have the same problem?
thanks, bye!
Post by fused » Thu Mar 22, 2007 6:31 pm
well... i have never seen this message.
what does the _bugReport.txt say?
geertz
Marcofly
Post by Marcofly » Thu Mar 22, 2007 7:35 pm
Hi! the bugreport says LOTS of things :shock: :shock: !! I can send it to you as PM, but before you loose your time with it, I am going to try with another PC, to check if the error will be repeated..
could you please check the \res\strings_us\description\tmyrendersettingsexp.str?
Besten dank! Thanks a lot!
Marco
Marcofly
Post by Marcofly » Thu Mar 22, 2007 8:56 pm
now it works..
please update the tmyrendersettingexp.str in english..
Keep on your good work!
Bye!
:D
Marcofly
Post by Marcofly » Fri Mar 23, 2007 1:28 am
found a small bug.. exr. lighting not working!
the lat_long lines are missing, should be like this:
<env_map>
<latlong>
<path>xxxxx.exr</path>
<gain>1</gain>
</latlong>
</env_map>
Ciao! Thanks..
Post by fused » Sat Mar 31, 2007 9:04 pm
finally, new release!
sry for the long delay.
INDIGO EXPORTER FOR C4D 0.2.5b
download exporter here (or below)
the file contains "sampleScene.c4d" for everyone who still doesnt know how to setup stuff.
fixed-list 0.2.5b:
* env-maps
* finally rotation (barely tested)
* should not crash on export (if it does pls send me your scene)
new in 0.2.5b:
* the often requested defaultMat (diffuse, r,g,b = 0.85)
* several things that i dont know anymore :P
* triangulation for .obj export
known bugs/issues 0.2.5b:
* sometimes you have to guess the right fields, didnt find out how to hide them yet
* normal problem. normal_smoothing = false by default
* some little memory leaks, should not cause problems, will be fixed soon
please post bugs :!: :!:
Indigo Exporter 0.2.5b.zip
Indigo Exporter for 4D 0.2.5b
(354.42 KiB) Downloaded 677 times
Phoenix
Post by Phoenix » Sat Mar 31, 2007 9:20 pm
Thank you fused for the new release! :D
And also thanks for implementing the default mat.
But when I export from C4D, the scene is still always named "justsomerandomcrap.xml" whether if I add the extension ".xml" to my chosen name or not. But the .3ds and .obj files get the right names.
The menue point "Info..." also seems to do nothing yet.
(I tried both of these with the C4D releases R9.6 and R10.1)
Post by fused » Sat Mar 31, 2007 10:00 pm
yes i know both issues.
im working on the filename. its about converting a cinema string to cstring for tinyXml. dont know how to do it (yet).
info isnt supposed to work.
Marcofly
Post by Marcofly » Sat Mar 31, 2007 10:28 pm
Thank you very much!! will test it soon!
Ciao! :D
Locked
