big problem with exporting......
10 posts • Page 1 of 1
Kosmokrator
Post by Kosmokrator » Thu Mar 22, 2007 7:05 am
hi suvakas i attach one of my objects in my new scene in max file format to make and u some tests...also i give an picture of wath i get...i dont understand...what happents?
i also tryed to export in xml and 3ds format....the same thing happends... :roll:
wtf.zip
(180.11 KiB) Downloaded 273 times
image rendering...box? :?
Post by Kram1032 » Thu Mar 22, 2007 7:29 am
wtf = good name for this :P
filippo
Post by filippo » Thu Mar 22, 2007 7:55 am
as you have realized the geometries?to importing...ecc
filippo
come hai realizzato le geometrie?importate?
filippo
Kosmokrator
Post by Kosmokrator » Thu Mar 22, 2007 8:02 am
filipo i dont understand what u mean.....the geometrie is editable mesh....i export them in 3ds and xml but give the same result....i think is deeper problem...suv please chek the scene and give me one solution....im about to crazy! :) thnx
Post by Kram1032 » Thu Mar 22, 2007 8:03 am
realized? Do you mean "applied"?
Î don't know, how the 3DsMAX exporter works, but... import? shouldn't the exporter automatically get the geometry?
Post by suvakas » Thu Mar 22, 2007 8:04 am
Scenes like this always come handy for finding bugs (yeah..like there is not enough bugs already :) ).
I'll check it out.
Suvakas
[edit] ups... I have only Max 7 at home. Will check the scene tomorrow at work.
Post by suvakas » Thu Mar 22, 2007 9:57 pm
The scene will render fine with next Maxigo version when using a new feature called "Fix Mesh Errors" :wink: (i'm not sure if i should turn that feature ON by default or implement it as a selection box (it is a selection at the moment)).
It isn't 100% fool-proof , but I've been able to render scenes, that were soo messy and didn't work even with M2I exporter, by using that new feature i "invented". It even exports actively linked Autocad models (no X-refed models though..those have to be merged to scene).
So hold on. I will release it as soon as possible (maybe on this week :) Depends on my workload in other areas).
Suvakas
Kosmokrator
Post by Kosmokrator » Fri Mar 23, 2007 4:25 am
ohhh my god......thnx suvakas i have a full modeled scene and i get 80% of my objects with this "boxed" error!
thnx again for your effort to this exporter!
filippo
Post by filippo » Fri Mar 23, 2007 5:35 am
suvakas wrote:The scene will render fine with next Maxigo version when using a new feature called "Fix Mesh Errors" :wink: (i'm not sure if i should turn that feature ON by default or implement it as a selection box (it is a selection at the moment)).
Suvakas
the"fix mesch errors" there is in this exporter or in the a future exporter?
filippo
Kosmokrator
Post by Kosmokrator » Fri Mar 23, 2007 5:43 am
in the future exporter filippo...... :wink:
