Landscapes
Re: Landscapes
Great yonosoy! How long does it take on your system for one frame? Maybe you could a make short animation of these landscapes
Re: Landscapes
About 2h in 4K, then downsized (better impression of polygonization). Just wait for some instancing and maybe GPU and we can talk about
Re: Landscapes
Still N042E000 (18 X 18 Kilometers, the Pyrenees).
Alos 2. The world with a detail of 30 meters per pixel. Worked, detailed and textured in Houdini.
Re: Landscapes
Great! You should try a low sunlight mood, or work with clouds
Re: Landscapes
10h in 4K, 3h in HD.
The clouds material of the HD version is smoother.
When all is ready I go till the final.
Hope you like
Hope you like
Re: Landscapes
Looks really cool!
Re: Landscapes
Wow yonosoy, better than I could imagine
This will go to be my new wallpaper!
Re: Landscapes
Just learning some skills... Thank you very much.
108 X 108 km. (the minimum map of Alos 2).
About three hours.
N030E078.
About three hours.
N030E078.
faisalahmed
Re: Landscapes
this pictures is amazing
Re: Landscapes
Hi and wellcome to the forum. Thank you.
At last, finally, ... Mie cumulus under control. No noise at all.
Mie Test.
Mie Test.
Re: Landscapes
Yeah, the dream...
Thank you for your words.
Like the top of the clouds mesh is missing some code I let it here.
The trick is to not use perfect spheres for this. With they, mie cumulus is grey, the fan of the CPU is too loud, ...
700 samples per pixel in 4K; 13 hours of process. Then downsized.
This means that there is a lot of light and color not present.
Re: Landscapes
Not sure, ... this puzzle. The noise is present, sorry. Maybe enough with metropolis path tracing (this is the modality of the test).
8 hours, denoised and resized.
24K maps.
24K maps.
Re: Landscapes
lovely!
