Indigo Renderer 4.0.54 Beta Release
10 posts • Page 1 of 1
Post by OnoSendai » Wed May 31, 2017 1:20 am
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.0.54_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.0.54.tar.gz
IndigoRenderer4.0.54.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.0.54_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.0.54.tar.gz
IndigoRT4.0.54.dmg
Changelog:
4.0.54
* Added support for GPU rendering with network rendering.
* Fixed tonemapping/image update not being done in some cases when halt condition is reached.
* Made it so that Indigo now accepts IGQ and PIGQ drag and dropping.
fourzeronine
Re: Indigo Renderer 4.0.54 Beta Release
Post by fourzeronine » Thu Jun 01, 2017 8:25 pm
OMG thank you will start testing.
Steven Garubba
Post by Steven Garubba » Sun Jun 04, 2017 3:21 pm
Hello,
I am using Indigo with Sketchup and I am noticing a bug with the fresnel channel not loading the reflection map into the render start. I'll start the render and have to set the channel up again for each material I assign a reflection map to.
Thank you,
Steven Garubba
Steven Garubba
Post by Steven Garubba » Sun Jun 04, 2017 3:25 pm
Steven Garubba wrote:Hello,
Thank you,
Steven Garubba
Oops, sorry I just saw the SketchUp forum side and noticed the beta that fixes that.
arc en ciel
Post by arc en ciel » Mon Jun 05, 2017 3:16 am
hello
here a pigs, where there is a bug or something like that inside.
It looks like if there is twice the same shader with same name etc, a problem occur.
In this file, there is two shaders named "BilleTr", this is the same mat duplicated.
In GPU mode only, the bead in the front is wrong.
if I assign to the bead the same shader used by the the stone, all is fine.
hope that help you.
have a nice whit monday
doubleShader.pigs
(21.4 KiB) Downloaded 562 times
Lal-O
Post by Lal-O » Wed Jun 07, 2017 6:18 am
Hi !!!
Sun Layer is not working when rendering with GPU. The preview gets full black and If you move the slider ( left or right ) Nothing happens.
Post by OnoSendai » Wed Jun 07, 2017 7:09 am
Lal-O wrote:Hi !!!
Yeah the sun layer is wrong on GPU, already fixed for next release :)
Lal-O
Post by Lal-O » Thu Jun 08, 2017 7:54 am
OnoSendai wrote:
Lal-O wrote:Hi !!!
Great news!!!
Another thing, i' ve also noticed that the satin glass (from the Skindigo plugin materials ) is not working as it should in GPU mode... It turns into a dark /mate material. It looks really weird. :p
Camonra
Post by Camonra » Wed Jun 14, 2017 5:30 am
With the Zotac GTX 1080, I'm getting no readout for Samples and all-black render output. The Firestorm GPU utilization is less than 6% and the GPU Memory Utilization is under 20%.
Post by OnoSendai » Thu Jun 15, 2017 3:34 am
Camonra wrote:With the Zotac GTX 1080, I'm getting no readout for Samples and all-black render output. The Firestorm GPU utilization is less than 6% and the GPU Memory Utilization is under 20%.
Have a look at the render log (under render settings on right of UI) and see what it says.
