Indigo Renderer 4.0.45 Beta Release
Re: Indigo Renderer 4.0.45 Beta Release
I can not start this version Indigo Renderer 4.0.45 Beta Release - My Windows 8.0, 64 bit.He writes that there is no file to run.
- arc en ciel
What's your exact CPU model?
Minimum CPU requirements to SSE4.1 support, AMD phenoms are too old.
My processor OctalCore AMD FX-8350, 4219 MHz (21 x 201)arc en ciel wrote:Hi,
I did experience that error on a offline copy of Windows. Copying the incriminated (missing) dll around from another up to date system did not fix the issue. Which Windows component is concerned with this ?Jaksi wrote:I can not start this version Indigo Renderer 4.0.45 Beta Release - My Windows 8.0, 64 bit.He writes that there is no file to run.
To start can = Visual c++ or Net Framework?
tar_gniK
- 3D Software: 3ds Max
What is the latest version of IndigoMax that is bundled with Indigo Renderer 4.0.45? There seems not be any info in the 3dsMax subsection (lack of activity in that section for quite some time now)...
IndigoMax-0.5.0 I think.
tar_gniK
Thanks Ono, I'll give it go ASAP.
- Originalplan®
[BUG]
OpenCL render mode does not work with generated image maps from Indigo Camera tag. ( Cindigo )
Also does not render obstakle maps. <> Uses the standard circle when switching from CPU to GPU.
Inside main app.
Inside main app.
Indigo Renderer 4.0.45 Beta Release Fri Sep 09, 2016.
It has been almost two months.....
New build coming sooncontegufo wrote:Indigo Renderer 4.0.45 Beta Release Fri Sep 09, 2016.
- Originalplan®
> Howling wolf icon here <OnoSendai wrote:
New build coming soon :)
The best from the best visualizers download scene for Indigo Renderer
4.0.40 https://yadi.sk/d/JGJCuqZquikMq and Indigo Renderer 3.8.31 https://yadi.sk/d/Sx2Kr2Ptt9gpJ
Congratulations especially to the last image. Poser + Indigo?
BRAVO!
BRAVO!
