by CTZn » Fri May 06, 2016 6:52 am
fourzeronine wrote:https://youtu.be/4ldme3vfWE0
Just a tech demo/proof of pipeline/art style for an animated short series I'm using Indigo for. 4 mins a frames with new Indigo 4 GPU rendering. Looks like I'll be dropping some cash on R9 Nano's or possibly Radeon Pro Duo's. My 2 7970's are getting 11M sp/s. I'm guessing 2 Radeon Pro Duo's should do 40-50M.
At this point of convergence, the renderer is not an object of debate in itself anymore... that's a visual gap bridged fo sho !
It's your own exporter that you are using, right ?
fourzeronine
by fourzeronine » Fri May 06, 2016 7:01 am
CTZn wrote:fourzeronine wrote:https://youtu.be/4ldme3vfWE0
I'm using your latest MtI. I just replaced the the code in the Gen script from
to
<gpu_path_tracing></gpu_path_tracing>
works like a charm, also working in latest Maya 2016 Extension 2
by Oscar J » Fri May 06, 2016 8:37 am
Cool 409! Looking forward to see more.
dakiru
by dakiru » Fri May 06, 2016 9:11 am
Hey, motion and quality are both very nice :)
fourzeronine
by fourzeronine » Fri May 06, 2016 9:56 am
thanks for the kind words :D
by CTZn » Fri May 06, 2016 10:12 pm
fourzeronine wrote:I'm using your latest MtI.
I'm glad I asked !
Silverwing
by Silverwing » Fri May 06, 2016 10:29 pm
Very very nice texturing / lighting indeed. I love dust and worn edges on the wood. This makes it so much more real. Great work there. Keep it up. I´m looking forward seeing more :-)
Cheers,
Raphael
davide445
by davide445 » Sat May 07, 2016 4:14 am
Maybe a known bug: exporting animation from C4D plugin 3.8.26.2 the GPU mode is used only in the first frame, the next one switch back to CPU mode.
by Oscar J » Sat May 07, 2016 5:26 am
I think a new Cindigo version is coming soon. :)
contegufo
by contegufo » Sat May 07, 2016 6:01 am
Hi
It reports an unpleasant moirè effect in rendering cpu that maybe is not new, after 9 hours.
davide445
by davide445 » Sat May 07, 2016 6:22 am
Oscar J wrote:I think a new Cindigo version is coming soon. :)
I can't also find a workaround.
Tried to force GPU rendering every frame, but at the fourth one I did receive an error message stating the GPU render mode is enabled but no resource is selected. My GPU was in fact selected as OpenCL resource.
Attached the igs file of the frame if that help.
- quickrender_frame000003.igs
- (36.64 KiB) Downloaded 309 times
by CTZn » Sat May 07, 2016 7:16 am
contegufo wrote:Hi
Are you using light layers with highly disparate values ? A very very weak rim light could lead to this maybe (or a too strong main light)...
contegufo
by contegufo » Sat May 07, 2016 10:19 am
There are two light areas with different temperatures K, may be responsible for the FSSS material?
by Oscar J » Sat May 07, 2016 10:56 am
contegufo wrote:Hi
That's just box noise which they've tried to fix for ages. That it's still there after 9 hours is not acceptable of course. A workaround is using MLT, but that'll be a lot slower...
davide445
by davide445 » Sun May 08, 2016 8:49 am
Testing the render of the attached grass pack I did got this error.
Exception while advancing OpenCL PT: clEnqueueNDRangeKernel failed for kernel 'l1lllll11ll1l1l111l11l111111lll11': CL_OUT_OF_RESOURCES
The render simply hangs in building the kernel.
The GPU RAM was at 500MB over 3GB available.
Driver 16.150.2211.1001 (Crimson 16.4.1)
- C4D-News-Grass-Pack.zip
- (1.39 MiB) Downloaded 300 times
