Pure GPU rendering in the Cinema 4D Plugin
8 posts • Page 1 of 1
Decade
Post by Decade » Mon Apr 25, 2016 9:13 pm
Firstly, congratulations on the V4 !
I'm a little confused about the Pure GPU rendering in the Cinema 4D plugin version (Not the standalone).
When I installed the V4 windows version, I was offered to install the Cinema 4D plugin, which has a 3.X number.
Inside, there is an option for GPU rendering but is this the new Pure GPU rendering mode, or the old Open CL/ Cuda slight acceleration ?
When I installed the mac version, I wasn't offered the plugin.
Is the Pure GPU mode in the plugin yet & if so in both mac & windows or just windows ?
Thanks for your help.
Cinema4D R13 Studio, Indigo RT, Zbrush4 R3
Re: Pure GPU rendering in the Cinema 4D Plugin
Post by Oscar J » Mon Apr 25, 2016 9:48 pm
An updated Cinema 4D version is coming soon afaik. :)
Post by pixie » Mon Apr 25, 2016 10:30 pm
It's curious that from within cinema plugin the problems I have on standalone doesn't show up. The GPU isn't used above 40% though, it seems as if the previous gpu is being used.
Post by pixie » Mon Apr 25, 2016 10:32 pm
pixie wrote:It's curious that from within cinema plugin the problems I have on standalone doesn't show up. The GPU isn't used above 40% though, it seems as if the previous gpu is being used.
It seems to be indeed the case as normal maps are working...
Decade
Post by Decade » Mon Apr 25, 2016 10:53 pm
Thanks, I think you're right.
I guess I can setup in Cinema then render in standalone for now.
Originalplan®
Post by Originalplan® » Mon Apr 25, 2016 11:43 pm
Decade wrote:Firstly, congratulations on the V4 !
Well it is the "old" GPU rendering inside the plug. AKA you can use 1 GPU.
But export the scene to Indigo App and render there. + you got plenty of features there too.
Decade
Post by Decade » Tue Apr 26, 2016 1:29 am
Yep, thats what I plan to do for the minute. I just wanted to check I had it right.
Originalplan®
Post by Originalplan® » Tue Apr 26, 2016 2:03 am
Yep you got it right. Go for it!
Users browsing this forum: BLEXBot [Crawler] and 54 guests
