Indigo Renderer 4 public beta
Not that there's anything wrong with comparing with Octane - that's actually a good thing. But those Octane scenes have 140k and 900k triangles respectively, while Arthur's scene has over 5M. Furthermore Arthur's scene has a lot of materials and textures. Your heavier scene uses about 250 MB of video RAM, while Arthur's scene uses about 1.3 GB.
There's a good chance of more optimising that will make your cards work, but for now - perhaps try some simpler scenes? Perhaps the same scenes you rendered in Octane?
Zom-B I don't need your answers.
I do ask that they pay developers?
Why doesn't GPU GF460 and 660?
Maybe I someone to give a concrete answer.
may configuration
GPU not working
GTX 460 2GB GDDR5 256bit
OpenGL 4.1
my 2600K CPU supports the instruction
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
Driver version: 364.72
Report on the NVIDIA system created: 04/12/2016 11:08:50
System name: 3DSERGEY-PC
[Display]
Operating system: Windows 7 Professional 64-bit (Service Pack 1)
DirectX Version: 11.0
Graphics processor: GeForce GTX 460
Direct3D API version: 11
The Direct3D feature level: 11_0
CUDA cores: 336
Clock frequency core: 700 MHz
Clock frequency Shader: 1400 MHz
Data transfer rate memory: 3600 MHz
Memory interface: 256 bit
Memory bandwidth: 115.20 GB/s
Available graphics memory: 4095 MB
Dedicated video memory: 2048 MB GDDR5
System video memory: 0 MB
Shared system memory: 2047 MB
Video BIOS version: 70.04.13.00.01
IRQ: Not used
Bus: PCI Express x8 Gen2
Device ID: 10DE 0E22 00000000
Set number: 1041 0001
NvGFTrayPluginr.dll 2.11.2.55 NVIDIA GeForce Experience
NvGFTrayPlugin.dll 2.11.2.55 NVIDIA GeForce Experience
nvui.dll 8.17.13.6472 NVIDIA User Experience Driver Component
nvxdsync.exe 8.17.13.6472 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.13.6472 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.13.6472 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.13.6472 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.13.6472 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.810.0 NVIDIA Control Panel
nvCplUI.exe 8.1.810.0 NVIDIA Control Panel
nvWSSR.dll 6.14.13.6472 NVIDIA Workstation Server
nvWSS.dll 6.14.13.6472 NVIDIA Workstation Server
PhysX 09.15.0428 NVIDIA PhysX
NVCUDA.DLL 6.14.13.6472 NVIDIA CUDA 8.0.0 driver
nvGameSR.dll 6.14.13.6472 NVIDIA 3D Settings Server
nvGameS.dll 6.14.13.6472 NVIDIA 3D Settings Server
nvLicensingS.dll 6.14.13.6472 NVIDIA Licensing Server
NVSTVIEW.EXE 7.17.13.6472 NVIDIA 3D Vision Photo Viewer
NVSTTEST.EXE 7.17.13.6472 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.13.6472 NVIDIA 3D Vision Module
nvDispSR.dll 6.14.13.6472 NVIDIA Display Server
NVMCTRAY.DLL 8.17.13.6472 NVIDIA Media Center Library
nvDispS.dll 6.14.13.6472 NVIDIA Display Server
nvViTvSR.dll 6.14.13.6472 NVIDIA Video Server
nvViTvS.dll 6.14.13.6472 NVIDIA Video Server
Before writing I do compare Oktan Render as the fastest and Indigo.
But I'm trying to ask the question why doesn't GPU GF460
may configuration
GPU not working
OpenGL 4.1
[Display]
CUDA cores: 336
IRQ: Not used
Me being the latest here that can give hints and I think you are a bit rude with someone that helped a lot of people, as beta tester and forumer. This IMHO.Prof4D wrote:Zom-B I don't need your answers.
may configuration
GPU not working
OpenGL 4.1
Anyway about your GTX 460 I didn't find it listed in the products that support OpenCL here
https://www.khronos.org/conformance/ado ... cts#opencl
So will not work for GPU rendering. About the 660 need to work and others can give you better hints.
Edit: looking here https://en.wikipedia.org/wiki/GeForce_400_series appear the 460 does support OpenCL 1.1 needed from Indigo, so better you follow others suggestions about your drivers version.
Still nobody understands what you want to tell us with your Octane images,Prof4D wrote:Zom-B I don't need your answers.
please explain what we see there and why this is important!
Please tell us what Indigos Render Log writes, this would really help to understand your issue.
I'm only unpaid Betatester but worked and tested the v4 Beta for many weeks now, and own 2 GPUs that are very close to yours, therefore I thought I could help since your very bad desribed problem sounded like having old GPU drivers.Prof4D wrote:I do ask that they pay developers?
I have a renderslave with an NVIDIA GTS 450 and a GTX 660 both run Indigo!Prof4D wrote:Why doesn't GPU GF460 and 660?
see here: http://www.indigorenderer.com/forum/vie ... =1#p135035
Don't expect miracles from your GTX 460
- Originalplan®
Hold your horses.Prof4D wrote:Zom-B I don't need your answers.
What? ^ ^Prof4D wrote:I do ask that they pay developers?
Octane is Octane and Indigo is Indigo.
I don't get the comparing of them. ( yep both GPU renderers but both are build on different tech )
If you want a fair comparsion wait for the finished V4 and use the same scenes as in you octane renderer.
Than you can conclude what App to buy.
PS: i would not be rude(ish) to Zom-B first he is a cool dude. And second it tells a lot about your character.
Third he can help you a lot if you encounter problems....and maybe you will need a helping hand in the future if you choose Indigo as your engine.
But who am i right? Just sayin. ^ _ ^
Not in my case:OnoSendai wrote: 4.0.31
* Fixed problem with Linux build.
[dak:~/Downloads/IndigoRenderer_x64_v4.0.31] % ./indigo
This application failed to start because it could not find or load the Qt platform plugin "xcb".
Available platform plugins are: linuxfb, minimal, offscreen, xcb.
Reinstalling the application may fix this problem.
zsh: abort (core dumped) ./indigo
Hey, can someone explain me what max allocation under Device Information means? I thought Zom-Bs Scence already uses more than 1GB of Vram. I read somewhere that Nvidia cards can only use 1/4 of Vram with Indigo, is that still the case?
Hi Vasco,
the max allocation is the largest amount of memory that can be allocated at once, e.g. for textures. Indigo will perform several memory allocations for textures and geometry separately, however any individual allocation must be <= this amount.
The Max Allocation reported by Indigo is the largest amount of memory that can be allocated at once with OpenCL, e.g. for textures. The practical limitation at this point is that the total texture size is limited to 25% of total GPU memory on NVIDIA, and about 65% of total GPU memory on AMD.
We might be able to work around this limitation in future, especially since OpenCL 2.0 promises unified CPU and GPU memory space. Until then, the AMD GPUs are very attractive given their performance / price / memory size and allocation limit!
With these environment variables:
This is the output:
export QT_SELECT=5
export QT_QPA_PLATFORMTHEME="qt5ct"
export QT_DEBUG_PLUGINS=1
export QT_PLUGIN_PATH=.Code: Select all
./indigo
QFactoryLoader::QFactoryLoader() checking directory path "/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqlinuxfb.so"
Found metadata in lib /home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqlinuxfb.so, metadata=
"IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
"MetaData": {
"Keys": [
"linuxfb"
"className": "QLinuxFbIntegrationPlugin",
"debug": false,
"version": 328961
Got keys from plugin meta data ("linuxfb")
QFactoryLoader::QFactoryLoader() looking at "/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqminimal.so"
Found metadata in lib /home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqminimal.so, metadata=
"MetaData": {
"Keys": [
"minimal"
"className": "QMinimalIntegrationPlugin",
"debug": false,
"version": 328961
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqoffscreen.so"
Found metadata in lib /home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqoffscreen.so, metadata=
"MetaData": {
"Keys": [
"offscreen"
"className": "QOffscreenIntegrationPlugin",
"debug": false,
"version": 328961
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqxcb.so"
Found metadata in lib /home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqxcb.so, metadata=
"MetaData": {
"Keys": [
"xcb"
"className": "QXcbIntegrationPlugin",
"debug": false,
"version": 328961
Got keys from plugin meta data ("xcb")
loaded library "/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqxcb.so"
QLibraryPrivate::loadPlugin failed on "/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqxcb.so" : "Cannot load library /home/dak/Downloads/IndigoRenderer_x64_v4.0.31/platforms/libqxcb.so: (/home/dak/Downloads/IndigoRenderer_x64_v4.0.31/libQt5Gui.so.5: version `Qt_5_PRIVATE_API' not found (required by /usr/lib/libQt5XcbQpa.so.5))"
Would like to see the benchmark results of the R9 390(X) or the Fury (X). Also interested in the upcoming Polaris and Pascal.lycium wrote: ...AMD GPUs are very attractive given their performance / price / memory size and allocation limit!
Yeah still no luck with Linux version. Hope they will fix it soon.
Any news on plugins front?
Dear Developers,
what about an upgrade option from Indigo 3 to 4? In the store We can just buy a new licence and the upgrade link inside Indigo is broken!
Thank you for your answer and consideration.
Upgrades on store may work now.
Go to your private order page and there should be a 'buy now' button.
Please *do not* buy an upgrade if you are entitled to a free upgrade!
Customers who bought Indigo since the 3.8 release (Dec 2014) are entitled to a free upgrade to Indigo 4!
(The free upgrades will be sent out soon.)
Updated RT builds. Should work now.
If the developers wrote the {using all your OpenCL devices NVIDIA, AMD and Intel GPUs} why doesn't it work for the GPU.
When you run Indigo 4.0.31 the result is a black screen.
GT 460
OpenGL 4.1
Driver 364,72
the K2600 CPU
GT 460
OpenGL 4.1
Driver 364,72
the K2600 CPU
Users browsing this forum: No registered users and 61 guests
