A versatile ISL inconsistency was fixed, barring from tricks
4 posts • Page 1 of 1
Post by CTZn » Sat Apr 09, 2016 10:35 pm
My terrain shader was using cyclical definitions references, and it used to work. Here, erosionCenter() is calling Noise() which uses absMult() (wich uses erosionCenter(), that's the catch) :
def erosionCenter() real:
	paramErosionCenter() + Noise(paramErosionCenterScale(), paramErosionCenterStrength(), paramErosionCenterErodedNoise())
def absMult(real x) real:
let	x = if(paramCanyoning()==1) abs(x) - erosionCenter() else x - erosionCenter()
in	if(x<0.0&&paramCanyoning()==0)	x*x*-1.0
	else		x*x
def Noise(real noiseScale, real noiseStrength, int eroded) real:
let	Noise = baseNoise(paramScale()*noiseScale, -center())
*	noiseStrength/paramScale()/noiseScale
in	if(eroded==1) absMult(Noise) else Noise
Well, not anymore:
Error while building scene: Error while loading phong material 'canyons': Tried to refer to a function defined later: Noise(float, float, int, opaque).
It was a kind of cool 'inconsistent' feature, more of a feature for me; is this wrong ?
Re: A versatile ISL inconsistency was fixed, barring from tr
Post by CTZn » Sat Apr 09, 2016 10:43 pm
If I should stop complaining because I'm a bad scripter you just tell me :D
Post by OnoSendai » Mon Apr 11, 2016 1:41 am
Sorry CTZn :)
Just reorder your functions so they are defined before use :)
EDIT: to be honest the reason that requirement was added is a bit lazy. The thing I am trying to avoid is circular definitions of functions, which are not allowed, and a simple way to enforce chat is to enforce a 'define before use' requirement.
Post by CTZn » Mon Apr 11, 2016 11:18 am
Actually I tried to wrap my mind in order to break that circularity but iirc the results were not as satisfactory otherwise.
Bad scripting skills probably (too lazy to lay an analysis down) ! Now that was lazy from me also, because I meant to play with my shaders, not to rewrite them :lol: nvm
