kklors render stuff
Re: kklors render stuff
Some more random stuff.
Actually some collabos in the works too atm, but more time consuming.
Wait a minute... are those Indigo clouds in that third render? :O
I was hinted a week ago that they might be but I'm wondering myself tbh. Thanks for your refreshing work kklors, the "wound" has got my special mention today.
Haha yes, the clouds are CTZn's box cloud shader, just tweaked and modified a lot.
Will be using it for sure for all kinds of stuff.
and done nicely, good job !kklors wrote:Haha yes, the clouds are CTZn's box cloud shader, just tweaked and modified a lot.
I'm hoping to release the terrain shader within a couple weeks, can't wait to see what you would achieve with it ! I fixed an inconsistency yesterday and it allows now for even more landscapes types !
:> thanks pixie, kudos to the thread owner. As already stated, my work does not exist if it is not used...
Some random stuff.
Raped by work pretty hard atm : /
CTZn is there a way to scale down the clouds by 100x or so? Like a 10x10x10 cm box or something in that direction.
The more we appreciate your beautiful creations. Another rally lovely render!
So cool.. took me a while to notice the ants in the foreground
Last one is a masterpiece! I'd love to know where you draw your ispiration from kklors...
certainly, the vertical scale is driven by the distance between the top and bottom altitudes, though you will have to bypass the related params and input real values instead, or delete then recompose the params within the desired ranges.kklors wrote:CTZn is there a way to scale down the clouds by 100x or so? Like a 10x10x10 cm box or something in that direction.
the horizontal scale is Scale iirc, or frequency perhaps, it can be edited likewise in order to reach the desired noise phases over a given distance.
then scattering and absorption should be adapted.
this is all written off the top of my head, the PC is a few km away as per usual when I get a connection. let me know in case I had forgotten a caveheat.
Thanks a lot people!
Finally time again. Some more random stuff...
Thanks man! To be honest from nothing particular. Usually random moments or shapes, artworks etc. But most often just by playing around and trying to make something out of random results.Pibuz wrote:Last one is a masterpiece! I'd love to know where you draw your ispiration from kklors...
Cool! Will check it out later today. Not completely sure I'll manage, but hope once I get at least close I can bother you with some more specific questions.CTZn wrote: certainly, the vertical scale is driven by the distance between the top and bottom altitudes, though you will have to bypass the related params ...
always deep and often intense works... well, you'll get bored with compliments !
actually I was anxious to know whether you would need the help, my pleasure.
Users browsing this forum: No registered users and 72 guests
